Results 11 to 20 of 28
Thread: GU air box gasket
    Quote Originally Posted by my third 256 View Post
    just purchaced 3 of these 2 for mates
    when we checked theirs they were broken and brittle heres a link
    http://www.ebay.com.au/itm/121576966...%3AMEBIDX%3AIT
    Be interested in what you think,
    Did Mega use some rubber from Clarkes Rubber
  2. #12
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    be interested in what you think,
    did mega use some rubber from clarkes rubber
    i used clarkes rubber works a treat
  3. The Following User Says Thank You to Sir Roofy For This Useful Post:
    threedogs (25th February 2015)
  4. #13
    176 Post(s)
    Just checked mine - seems ok.
    However - a ‘supplementary question’ .
    Whilst I had the airbox lid off I noticed a small hole in the bottom of the airbox, obviously a drain hole. Drain hole on my old bus had one of those squeezy rubber tubes attached to allow water out, but not in, but this is just a hole with nothing to attach a tube to. Does that sound right or is something missing? I’ve sealed it with a course thread tek bolt & rubber washer (from underneath).
  5. #14
    It may be a drain hole for the snorkel , to let water out
  6. #15
    176 Post(s)
    Surely snorkels would have their own drain point somewhere before the airbox itself wouldn’t they? So does your airbox have a drain hole?
    The bottom of the airbox has a raised concentric lip which is outsided of the diameter of the filter. the hole is between this lip & the side of the airbox. Looks to me that the design is to allow a certain amount of water in the box without it getting sucked into the motor. However it has the potential to let water in during a deep water crossing. I guess with it blocked off I’ll just need to remember to check for water in the airbox from time to time.
  7. #16
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by cuppa View Post
    just checked mine - seems ok.
    whilst i had the airbox lid off i noticed a small hole in the bottom of the airbox, obviously a drain hole. Drain hole on my old bus had one of those squeezy rubber tubes attached to allow water out, but not in, but this is just a hole with nothing to attach a tube to. Does that sound right or is something missing? I’ve sealed it with a course thread tek bolt & rubber washer (from underneath).
    my air box is the same theres a thread here some place about them sealing it with silicone
  8. #17
    Never had a good look inside the air box but driving when its flogging down ,
    I'd want to water to be able to drain.I've had the water half way up the windscreen
    going to Bearii just after the gate on suttons lane {no snorkel} and no water ingress as well.
    most snorkel fitters do some thing to the air box what that is I dont know
  9. #18
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    If you have a snorkel and you get ANY water in your air box - you have a problem somewhere. Usually it gets in via a poor seal either on the airbox or somewhere on the snokel's plumbing, or the hole in the bottom of the air box (that usually has a rubber valve in the ones I have looked at anyway) has not been sealed.
    Or - of course - you were in water which was above the snorkel!
  10. #19
    476 Post(s)
    As far as I am aware Bill there is only a hole in the GU boxes. When I worked for Donaldson we sold tonnes of those "Vac Valves". But they were primarily for the larger housings. I thought to block that hole but if any water to get in it would no where to go so I left it.
  11. #20
    Expert Paule's Avatar
    Jan 2014
    Sandhurst
    I have an 03 3ltre and it has a hole in the air box (maybe 3mm) with no rubber piece or any way to connect anything to it. It is just a hole, and I have no snorkel
    03 ST-L auto, Dawes and needle valve, provent catch can, 3' exhaust. I want more than I got
