Results 11 to 20 of 21
Thread: LRA auxiliary tank fitting instructions for a GU
    Jan 2013
    Adelaide
    Thanks for that Mark, does the straight upright bracket attach to the standard tank bracket?
    2005 GU IV 3L ST-S Mods: 3in Zorst, chipped, Autron egt, boost and dual voltage gauges, pillar pod, dual battery, IPF round spoties, Nissan alloy Bullbar.
  2. #12
    476 Post(s)
    Quote Originally Posted by Badball View Post
    Not sure tbh. But I assume it will.
    Badball (20th February 2015)
  4. #13
    Jan 2013
    Adelaide
    Hi mark,
    How did you go with fitting your tank? I've dummy fitted mine and am just wondering if you could help me out with the back left rear straight bracket on where does it attach to?
    image.jpg[ATTACH=CONFIG]56064[/ATTACH
  5. #14
    476 Post(s)
    Gimmie a bit bud. I wanna photo chop the pics so they are easier to understand....
    But the original steel bracket that holds the rear of the old tank needs to come out. As I used this bolt hole as a mounting point for the bracket I made up. But it looks like you have removed it anyway.... That arm on your LR tank is straight. Mine was bent outwards...
    Heres the pic of the bracket I bought and slightly modified to use....
    Heres the tank sender, cut and extended so its about 10mm off the bottom of the tank, exactly how it was in the original tank....
    Badball (11th March 2015)
  7. #15
    476 Post(s)
    While I'm here. Anyone know what this does? It was in the centre of the original aux tank. In the centre tray, I suppose you'd call it, where the pickup tube sits. The was nothing attached to this thing, just clipped onto the edge of this tray. I'm thinking I may slow the wave effect somehow of the fuel where the pickup tube is maybe.
  8. #16
    Jan 2013
    Adelaide
    Thanks Mark. Funny enough I have 2 of those angle brackets sitting on my shelve in the shed and was looking at them this afternoon thinking they would work. Thanks again for your help 👍
  9. #17
    476 Post(s)
    Thanks Mark. Funny enough I have 2 of those angle brackets sitting on my shelve in the shed and was looking at them this afternoon thinking they would work. Thanks again for your help 
    Too easy mate. I sat there for ages on Saturday arvo thinking how I could do it. BA came over and had a look, then left. I cracked another stubbie, asked on here, had a scotch, then the light bulb came on. It seems for me that I need to post up here about it, then I figure it out. Happened a few times for me. Lol
    The top mounting bolt uses a 17mm spanner on it. the lower side mount I used a larger bolt (with a 19mm hex), mainly because the sheer factor of the larger bolt would be better as the tank would be pulling down.... If you get my drift..
    Badball (12th March 2015)
  11. #18
    Hey, whatever works.
  12. #19
    Apr 2025
    Bit late to the party, you guys just use the one rear bracket to mount or is the second one meant to go somewhere also?
  13. #20
    Apr 2025
    How'd you go with the mounting at the back? Just one mount or is the other one used somewhere... because mine just goes onto a welded area on the chassis?
