Results 1 to 2 of 2
Thread: Clutch fan - EF Twin Thermos
    Feb 2015
    Hi. I'm currently in the stages of taking the clutch fan out of my 89 GQ, now I'm not sure when wiring up the fans, should I wite them up individually with 2x 50A fuses, if so can they both be run off the same switch? TIA
    Jan 2014
    Toowoomba
    You also need to wire the into your air con circuit as one needs to come on for the condenser, irrespective of the engine temp.
