Results 11 to 20 of 24
Thread: Gq Brake bias
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    If you look at the GU repair manual under the "Brakes" section (BR) it gives you a diagram of the valve and lever and a table which tells you distances between certain points as a means for adjustment.
  2. The Following User Says Thank You to BillsGU For This Useful Post:
    Bloodyaussie (8th February 2015)
  3. #12
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    I rebuilt my brakes not long ago and found the grease had dried out and gone stiff. Worth a check Jonathan, just in case.
    IMO and should be taken with a grain of salt.
  4. The Following User Says Thank You to Parksy For This Useful Post:
  5. #13
    Expert billyj's Avatar
    gordon
    the 4 inch lift would have ment new brake lines front and rear yes? i bet you still have some air in the fronts. took me farkin ages to get all the air out when i reco'd my calipers and changed the lines
  6. #14
    Jan 2013
    Nowra NSW
    5 Post(s)
    Yes the fronts are a nightmare to bleed. Regular bleeding didn't work, so I tried gravity bleeding and it did the trick. Solid brake pedal. Dead easy as well. Hook a hose up to the bleeder and crack it open. Have the brake reservoir open, so the fluid will flow and can be topped up. 20 mins per wheel, just dripping away into a bucket. Worth a shot and very little effort.
  7. The Following 2 Users Say Thank You to Parksy For This Useful Post:
    growler2058 (9th February 2015), mudnut (8th February 2015)
  8. #15
    Funny you post this now as today me and a mate were driving down into Walhalla, I was towing the camper and when we got into Walhalla both our GQ's had smoke coming from the rear left brakes
  9. #16
    Thomastown, Melbourne
    6 Post(s)
    As was the same with me coming into Captains Flat.....?
    I have not had a chance to look at it yet as I spent the weekend shooting and the rest trying to be the perfect husband and dad.
    The brakes were bled at the workshop by Georges brother and I can tell you they were done properly.
    The lines went in before I went to 4 inch lift.
  10. #17
    I have just not long ago put all new discs and pads too
  11. #18
    Mine did then as well
  12. #19
    6 Post(s)
    Was having a read and the distance on the spring with the brake depressed should be 220mm long, I have not had a chance to check this as yet as I do not want to start the car just so I can check the brakes.. This is a starting point anyway.
    It does not mention in the manual that I could see about the plunger being depressed at all?
  13. #20
    I'll check mine at home tonight
  14. The Following User Says Thank You to Winnie For This Useful Post:
    Bloodyaussie (10th February 2015)
