Page 462 of 1057 FirstFirst ... 460461462463464 ... LastLast
Results 4,611 to 4,620 of 10566
  1. #4611
    .......... TPC's Avatar
    63 Post(s)
    And ........... first impressions?
    And what did your fitting cost?
    I’m picking up my Redarc gauges tomorrow, so can now finally book in the car to get the exhaust fitted. (Waited so the exhaust fitting place can put the pyro sensor in at the same time).
    First impression is notably more power and the boost comes up quickly, much nicer to drive.
    Installation cost was higher than i thought it would be at over $400, they had to replace the studs on the turbo.
    I rang a few places and they all charged the same hourly rate and would not give a fixed price.
  2. #4612
    178 Post(s)
    Good to hear, I’m looking forward to getting mine fitted.
    Just picked up these babies this morning. (Now I just gotta suss out how to wire them up!)
  3. #4613
    If you have gauges fitted have you noticed lower EGT's or faster spool up
  4. #4614
    63 Post(s)
    Have not wired up the Pyro yet, will do it this weekend but never had it on old exhaust so can't compare.
    Definitely noticed the faster spool up.
  5. #4615
    178 Post(s)
    I just booked in for Saturday morning to get mine fitted. On the phone they reckoned $240 “plus a bit extra if the turbo studs are a problem". I started to tell him how Genie say to re-use the turbo to dump pipe gasket & he was already across that which gave me a bit of confidence in them. I feel a bit like a kid the night before Christmas.
    Did you have the exhaust joint fit the Pyro sensor or are you going to do it yourself?
  6. #4616
    Patrol God Stropp's Avatar
    38 Post(s)
    finally got the 4.33 diff gears and pinions in and wired the blackvue to permanent power so it recirds all the time when moving or on a movement sensor when parked, the diff gears make it easier to take of and for cornering you dont need to change back down a gear, now i just need to get it down the beach for a workout. Also changed a tie rod end that was giving a slight wobble in the steering.
  7. #4617
    Perth WA
    63 Post(s)
    New radiator, water pump casing thingy............don't know what else, been at my mechanics for 2 days so far getting ready for my trip
  8. The Following User Says Thank You to Woof For This Useful Post:
    Stropp (5th February 2015)
  9. #4618
    63 Post(s)
    I had them fit the Pyro sensor and tie up the cable for me to wire up.
  10. #4619
    Western suburbs of Melbourne
    12 Post(s)
    Yesterday I got my trailer plug socket replaced as I ripped off the lid, the aux battery replaced under warranty, as it failed again.
    I got a rattle in the rear barn door fixed, they found a loose bolt that needed tightening.
    Also have my 90k service getting done today.
  11. #4620
    Oct 2014
    Sedgwick Victoria
    Built a set of draws for the back with a slide out table, added USB, 2 x 12V & Anderson plug for fridge. Still to come fridge drop slide.
