Page 480 of 1466 FirstFirst ... 478479480481482 ... LastLast
Results 4,791 to 4,800 of 14660
  1. #4791
    84 Post(s)
    Quote Originally Posted by ova50 View Post
    Tyre Shops who have this obsession with tightening wheel nuts so tight, the Hulk would have trouble undoing them .
    The tyre shop I use have those rated torque extensions for their rattle guns. A couple of them shattered after prolonged use. They have started using a normal extension to get the nuts tight then swapped to the rated extension. I have had no problems, but I usually check the nuts with a torque wrench at home.
    Is the tyre shop the regular one you use? If it is, and they are over tightening the wheel nuts they may be weakening the studs.
  2. #4792
    brisbane
    Just had a hail storm come through and dent up my 2012 ford ranger!
    we are getting a new renalt master delivered in a week then had planned to sell the ford! Now I've been told there's a 6 month wait on pannel beaters due to previous storms in Brisbane.
    ffs!
  3. #4793
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Quote Originally Posted by megatexture View Post
    ffs!
    Hope for a write off. If it's bad enough it should be gone
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  4. #4794
    brisbane
    Its prob worth more as a write off aswell. I doubt it will be though its not huge dents just lots.. Like one every 30 mm and its only a single cab.
  5. #4795
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Got my new eye glasses on Friday, only to discover that they have been made incorrectly.
    They were that bad that I can see better with no glasses.
    Now have to wait for up to another 2 weeks for them to correct the stuff up.
    Was a CRD
  6. #4796
    Washed the car yesty and found a 4inch long dint in the left rear passenger door.
    threedogs (1st February 2015)
  8. #4797
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    washed the car yesty and found a 4inch long dint in the left rear passenger door.
    shopping trolly ?
  9. #4798
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Damn, gotta hate that! Did you end up getting any panel damage in your front drivers door from that bog hole at Tallarook that you were trying to to winch around the corner?
  10. #4799
    Quote Originally Posted by roofy View Post
    shopping trolly ?
    Looks to me another car door. Its below the centre black door strip that runs horizontal....
    Funnily enough! Not even a scratch.
  11. #4800
    Quote Originally Posted by coop View Post
    Had a sparky out last night and found out that some dick head had put two wires in the fuse box in the wrong place it turn out they had the power wire in where the off peak hot water wire was supposed to go and the hot water wire where the main power wire was meant to go, the sparky had it fixed in 10 minutes, talk about confusing, all good now.
    Damn. The reason they did that was the circuit for the hot water is billed at a MUCH LOWER PRICE. Less than half. Very illegal to hook it up like that but expect your power bill to increase significantly. Sorry mate.
