Results 1 to 7 of 7
Thread: Gearbox oil
    Dec 2013
    Australind WA
    Gearbox oil
    Just wondering what's the best oil to run in my manual box in a diesel gq. And in the transfer. And how much they hold cheers
    Feb 2011
    Shed
    45 Post(s)
    I used Castrol 80w 90, cant remember how much, but you'll get that info from the manual. Remember to make sure you can undo the fille plug before you drain the oil, they can be a right bastard to undo. I used an electric rattle gun,s 1,2 inch drive to undo them.
  3. The Following User Says Thank You to growler2058 For This Useful Post:
    Shaft10 (3rd November 2014)
    Make sure the oil has a GL-4 specification.
    Dec 2013
    Australind WA
    Thanks fellas I ended up find castrol oil that was right
    Beginner snakessou's Avatar
    [Remember to make sure you can undo the fille plug before you drain the oil, they can be a right bastard to undo. I used an electric rattle gun,s 1,2 inch drive to undo them.]
    i mad sure on my gu 2.8 that i could take the fill plug out, then i attempted to take the drain pull out with no joy.
    who ever done the change last time has mashed the inside of the plug with a 1/2 inch driver.
    how in gods name am i going to get the bugger out now?
    i know i could just use some sort of hand pump and remove the fluid from the side and then fill it but jee wizz should i have to?
    84 Post(s)
    Gidday, snakessou. I bought a new plug and I had to take my Patrol to an engineering place to get an old impact socket mig welded to the old plug. Even with the socket it took a breaker bar and a metre long pipe to crack the plug open.
  8. The Following User Says Thank You to mudnut For This Useful Post:
    snakessou (24th January 2015)
    sounds like fun
