Results 11 to 20 of 23
Thread: Does any other Winch fit the factory Nissan Bullbar on a 2011 GU CRD?
    Mar 2013
    NE Melbourne
    These photos show the Runva 9500-Q winch in the Nissan steel bar.
    This pic shows the control box mounted inside the bar out of the weather. Top is exposed a little but the control box is 100% water proof. The winch rope is generally well protected from the sun and rain. It would not get much direct sunlight.
  2. The Following User Says Thank You to Rock Trol For This Useful Post:
    hybrid (24th January 2015)
  3. #12
    Jul 2014
    Hill End NSW
    Great, thanks Rock Troll, did you use Dynema Rope or cable?
  4. #13
    Mar 2013
    NE Melbourne
    It's the Dyneema version.
    The difference between the two is the cable (steel or dyneema rope) and the fairlead, roller or hawse. The steel rope comes with the 4 roller fairlead while the dyneema has the aluminium hawse as in the pictures. No rollers. The rope just runs over the smooth aluminium surface.
  5. #14
    Jul 2014
    Hill End NSW
    I am thinking I should get the rope, but it's weird trusting the rope to pull such a heavy vehicle out of a sticky situation, in saying that heaps of people seem to use it though.
    Quote Originally Posted by Rock Trol View Post
  6. #15
    Dyneema [tm] has been around for a very long time , first it is much safer to use as it does not store energy
    like SWR, If Dyneema breaks is just falls to the ground ,so less chance of injury. It floats too
    and for the size used is incredibly strong for its size, you can splice it in the field if it breaks, something you
    cant do with SWR.
    Just using Dyneema 10mm and an alloy or nylon hawse saves quite a bit of weight as well.
    Prices have come right down and 35 mtrs will cost you under $200 theese days.
    I had eyelet swaiged onto each end of my SWR and if going right off the beaten track I can use that as an
    extension.
  8. #16
    Expert Smoothrun's Avatar
    Dec 2012
    Vic Melb
    http://www.nissanpatrol.com.au/forum...ine-Nissan-Bar
    Dunno if its too late but I started my install with pics tonight if your interested
    Cheers, Dave
  9. The Following User Says Thank You to Smoothrun For This Useful Post:
    hybrid (29th January 2015)
  10. #17
    Dec 2012
    Vic Melb
    [QUOTE=Rock Trol;574680]These photos show the Runva 9500-Q winch in the Nissan steel bar.
    I dont want to sound rude and in no way any offence but I think this needs clarification RockTrol, unless i got an old unit.
    I bought my 11XP today and the control box is in no way 100% waterproof, in fact there is no significant point I could make about it being waterproof. It has a metal base plate with holes and a metal cover that is as helpful as a whitegoods cover, having said that I dont think it is majorly important to be 100% waterproof, it looks good enough to go underwater IMHO
    Im happy with that, Ive read only twice people silicone them up solid because of corrosion, but personally i think they have over reacted. In the end it comes down to maintenance, in winter months ill spray it up with silicone grease and not plug up the base plate like ive read, drain holes i recon. In the summer give it a spray after crossings if need be. The rope needs maintenance so may as well check the electrics whilst your at it. Either way everything gets operated whilst checking.
    I can see where you mounted your control box RockTrol, looks good, but how did u mount it, im at that point at the moment so id appreciate your feedback.
    Cheers Dave
  11. The Following User Says Thank You to Smoothrun For This Useful Post:
  12. #18
    Mar 2013
    NE Melbourne
    Hi Smoothrun..
    I should have written solenoid not control box. According to the web site they are: "100% Waterproof competition grade solenoid". The box may not be waterproof but the solenoids are. Then again, moisture might start corroding the contacts.
    The control box is fitted via a bracket that bolts to the bull bar, just behind the number plate. The steel is doubled walled there so the bracket bolts to the back and extends towards the radiator. As you can see from the picture the control box is mostly behind and under the grill. Just the plug peaks out. I don't have a picture at the moment though and you can't see much.
    If no bracket came with the winch then mine would have been fabricated by Pro 4x4 when they fitted the winch.
  13. The Following User Says Thank You to Rock Trol For This Useful Post:
    Smoothrun (30th January 2015)
  14. #19
    Dec 2012
    Vic Melb
    Yeah, I agree with ya about the solenoid, and they do look realy good, I dont think we will have any dramas as long as they are maintained
    As far as the mount goes Ive sorted that out then. was just waiting to see what you had done. Cheers and thanks
    Lifes a journey not a destination.
  15. #20
    Advanced Ironman 4x4's Avatar
    Jun 2013
    Ours fits
    Just gotta rotate the gearbox - but you need to do this on all winches.
    Cheers,
    Matt
    Ironman 4x4
