Results 11 to 20 of 35
Thread: Need new spotties
    not here yet thanks
    where do PMs and emails go that are lost???
  2. #12
    Advanced XT43's Avatar
    Mar 2013
    I put a set of these on my Tarmac rally car last weekend, couldn't be happier.
    Build in ballast, neat and tidy wiring to the hi beam and all set to go.
    http://m.ebay.com.au/itm/171187138475?nav=SEARCH
  3. #13
    Quote Originally Posted by XT43 View Post
    Are these the same? Only in 9"
    http://pages.ebay.com/link/?nav=item...831271&alt=web
    Disregard the above, was looking at a different set, but can't find then now.
  4. #14
    I have a 9" set of these I converted to 100 watt HID.
    I had new poly glass len's cut as they only have shatter glass in them ATM
    Since then Ive also found covers to suit
  5. #15
    Jay cee do you have the factory bar as in you dont have much room to fit Driving lights.
    I have new 9" x 55 watt 6000K Hid but may not be what youre after, they have a clear blue ring that lights up with the parkers if desired
    $150 a pair if you like them.
    I originally used two spread they were that good but changed to two spot cause I can lol
    I have a tjm bar.
    Do I need to buy a hid kit?
  6. #16
    if you have spotties {halogen} you could buy a slimline HID kit and fit them yourself.
    Slimline is just the size of the ballast, colour wise 6000K is a nice white light with just a hint of Blue.
    The blue helps cut through the air.
  7. #17
    As mudski has mentioned earlier, I don't want to get a crap kit. If I can $$$ wise would like to upgrade the hi/lo beam lights as well. What have people found to be good value.
  8. #18
    HID headlights are on the way out I think and 72watt LEDs with a fan for your hi/lo requirements are the go
    Stropp just fitted them and some LED 9" driving lights.
    LED have a long way to go to get distance but give out a great white spread of light.
    All my HID kits have cost $100 and under and still going strong 4 years later. even all my "cheap"
    interior led's are still working "every" globe on my patrol are either led or HID
    jay see (22nd January 2015)
  10. #19
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I've got a set here that you can have
    Lucus30's 1999 GU ST TB45E
  11. The Following User Says Thank You to lucus30 For This Useful Post:
  12. #20
    Mar 2013
    You can get the same in 9 inch and they all come with clear plastic clip on covers. I think the 9 inch are only $20 more.
  13. The Following User Says Thank You to XT43 For This Useful Post:
