http://www.ebay.com.au/itm/121289905...84.m1423.l2648
I'll be buying this when funds allow. good thing other than tyre inflation you can blow dust off gear or airfilters if in a bind.
I'll be fitting a 2-3 gallon tank underneath very soon . You could even run air tools to a certain degree.
Be wary if you mount the compressor under the bonnet as under bonnet temps may trip the thermal switch in the pump.
You might be better making a purpose built box for your compressor to keep it nice and clean and easy to store
