Results 1 to 10 of 498
Thread: Outback Ideas Recovery points
Threaded View
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by sg1 View Post
    will be interested on front recovery points for my 02 patrol with nissan steel bar soon, did read through the threads the other day but cant remember if i needed to have captive nuts to bolt two recovery points on the front and remove bar which sounds like a bit of effort to install?, currently has hook on drivers side.
    you should have captive nuts on left side same as right under hook
    you will need to make the holes a tad bigger unless john has already fixed that problem
  2. The Following User Says Thank You to Sir Roofy For This Useful Post:
    SG1 (13th January 2015)
