Results 1 to 10 of 17
Thread: King Springs Koni front setup, Air bag Rear
    Expert Smoothrun's Avatar
    Dec 2012
    Vic Melb
    Ive been doing some research but still a little dazed by the fact theres alot to learn and consider, I knew it probably would but hey its always worth it. From what i can gather and been told by a diesel mechanic nephew I thought would be worth throwing it out here and see what i could,should consider.
    My 2014GU is stock.
    I want to upgrade to 33s
    I want a 2" lift
    Im thinking about the following based on my little knowledge, and hoping to get a desired outcome that gives me a gentle ride towing a trailer for firewood and others for boats
    The front setup Ive driven yotas with them on and off road and liked them, unfortunately just not in any of the later model gu,s
    Im looking for King with Konis for the front and airbag the back to allow for my different towing weights, i have an onboard compressor so thats covered.
    Has anyone done this and can provide feedback, pics, part numbers, dos and donts.even recommendations for a reputable supplier to install. Im in Melbourne
    Western suburbs of Melbourne
    11 Post(s)
    Not sure which part of Melb but Stretch had both his cars in kings and Koni's, through a mob called ONTRACK 4x4 in Kealba in the western suburbs if that's any help.
    He loves the set up, using adjustable shocks to get the ride how he wants it.
  3. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    Smoothrun (10th January 2015)
    Have a talk to Andrew at On=Track in Malcolm crt Kealba
    Not much he doesn't know about Patrols and what combos work and what don't
    I'll Pm contact details for you
  5. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    MEGOMONSTER (9th January 2015), Smoothrun (10th January 2015)
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    There is some good info here on a full air suspension setup, worth checking out for some ideas:
    http://www.patrol4x4.com/forum/suspe...67/index4.html
    http://www.patrol4x4.com/forum/nissa...sion-gu-28838/
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
  7. The Following User Says Thank You to Crate For This Useful Post:
    Smoothrun (13th April 2015)
  8. #5
    Legendary happygu's Avatar
    Smoothrun,
    I always run Koni's and usually Kings Springs too .... great combination in my opinion.
    Koni's head office is in Vermont Melbourne if that helps, where they do supply and install .... try progressive rate coils in the rear for a softer unladen ride
    Mic
  9. The Following User Says Thank You to happygu For This Useful Post:
    Smoothrun (19th February 2015)
  10. #6
    You can run the 33''s with the standard height suspension too, if you want to get the tyres done first
  11. The Following User Says Thank You to happygu For This Useful Post:
  12. #7
    I've only heard good about Konis especially on coil suspension 4x4 ,
    adjustable and rebuildable whats not to like
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #8
    Patrol God Stropp's Avatar
    37 Post(s)
    i have bilstiens and they also work very well and are rebuildable too.
  15. The Following User Says Thank You to Stropp For This Useful Post:
  16. #9
    Patrol Guru paulyg's Avatar
    Ballarat
    I have king springs , bilstien shocks and air bags in the rear, very happy with the set up, make shure you get the right spring rate to suite your load and accessories.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
  17. The Following User Says Thank You to paulyg For This Useful Post:
  18. #10
    Dec 2012
    Vic Melb
    Thanks threegods. Got ya pm. Greatly appreciated. Ill assess the feedback and ring around next week. Cheers
