Results 1 to 6 of 6
Thread: Major problem with VDC function following 20,000km service
Threaded View
  1. #2
    Legendary happygu's Avatar
    Matt,
    Hard to know what the exact problem may be.....
    Check with the Service Guys if they did an ECU Update during the last service, as that may be the cause of your little problem, as they may have 're-calibrated' the VDC in a software update.
    Failing that if you don't want to pull the fuse, you could maybe add a switch into the power feed from the ABS Fuse, and locate that low down on the dash near the fuel cap filler release ( This is the spot where they normally put the old 4.2 Hand Throttle Lever ) .... then all you need to do is push the switch. Make sure you have a light on it too ,so you remember to put it back on for the road.....
    Mic
  2. The Following User Says Thank You to happygu For This Useful Post:
    docp1980 (7th January 2015)
