Results 11 to 20 of 22
Thread: Long range sub tank
    Quote Originally Posted by sr06 View Post
    So that should be a 70ltr stropp? Would it bolt straight in and use the same sender and plumbing?
    Yes. Should have no trouble
    sr06 (5th January 2015)
  3. #12
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    i reckon that one pictured is probly for a ute, looks way too tall to fit under a wagons floor
    looks like mine as well Stropp - came out of a wagon - went back into another wagon........
  4. The Following User Says Thank You to Bigcol For This Useful Post:
  5. #13
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    yes it will fit
    yes the sender should work (mine the petty ones have different wiring for the sender units so had to modify that)
    all the plumbing fits........
    just not a lot of room between the tank and the chassis - a few barked knuckles
  6. The Following User Says Thank You to Bigcol For This Useful Post:
  7. #14
    Jun 2011
    Rockhampton Q
    Ok cool thanks very much guys
  8. #15
    Yes it will use the same sender I think its negitive off when empty.
    Dont rely on the gauge too much the first half of tank is a bit iffy.
    I have the Brown Davis 75ltr Aux tank, my range is about 1100 now I would think
    sr06 (6th January 2015)
  10. #16
    You just bend the sender unit's dip stick arm John to suit the deeper tank. Mines sitting here and was supposed to go in before this monday when we go away. But it still needs a inside clean, a fair bit of surface rust in it, and I don't have time to do it. Just wondering how long it will take to do the remove and refit.
  12. #17
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    not long if you remember to remove the flap inside the back r/h wheel arch to get at the filler pipe
    and the cap covering the sender unit and depends on whether your got a hoist or crawling around on the floor
  13. The Following User Says Thank You to Sir Roofy For This Useful Post:
  14. #18
    Yes and its negitive off when empty I wouldn't rely on the accuracy of the gauge after 1/2 tank mine is not bad
    Took Kev and the boys a bit over an hour to fit with a hoist
  15. The Following User Says Thank You to threedogs For This Useful Post:
  16. #19
    Aug 2010
    adelaide
    hey guys i think that is the belly tank for when they put in a lpg tank in the rear
    only saying this because had this in my 95 gq and what gives it away is the exre square bit on the end
    with etra bit was 90 ltrs
    without 70 ltrs
    OH LEATHER IS NICE
  17. #20
    Jun 2011
    Rockhampton Q
    Hay guy is it ment to come with another bracket or something the filler pipe hits on the rear mount and carnt see where the 2 rear mounts on the tank hook up to
