Results 21 to 30 of 41
Thread: coolant/radiator issues
    Nov 2013
    QLD
    I didn't think you could put a sender in the radiator. Is there a free spot in the thermostat housing. I putting one in mine, but don't like the look of the inline ones.
    I am unsure what the best place would be, what's the thermostat housing?
  2. #22
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Quote Originally Posted by dannypatrol View Post
    Follow the top radiator hose from the radiator to the thermostat housing Danny
    1999 GU 4500 dual fuel
    Il dado è tratto
  3. The Following User Says Thank You to NP99 For This Useful Post:
    dannypatrol (3rd January 2015)
  4. #23
    brisbane
    Not sure why you couldn't? Well not that I have heard anyways, I just thought being an aftermarket radiator his may have a bung for accessories( low coolant alarm, temp sender etc). I've been using an inline one for 5 yrs now without any leaks.
  5. #24
    Feb 2013
    Broadford VIC
    I think you can also put one in the hose. Eric from down Coffs Harbour did one last year from memory.
    Il dado è tratto
  6. #25
    Yeah that would be a inline one.
    I'll rather put on in the the thermostat, looks neater IMO.
  7. #26
    brisbane
    Danny I just remembered I have a spare plastic pod that came with a gauge if you want it its yours, I didn't use it as it didn't match my others
  8. #27
    Nov 2013
    QLD
    Quote Originally Posted by megatexture View Post
    Thanks heading to supercheap today to look for the gauge and sensor. Will look if the radiator has one of those inline and otherwise try to fit it in thermohousing.
    I contacted pwr for any of there advise, considering the radiator can't be opened and cleaned, but they couldn't do much.
    So if I fitted the temp stuff, then just do a test drive and record temps?
  9. #28
    Cant you get an alloy bung tigged into the top tank somewhere?
  10. #29
    It needs to be after the thermostat but as close to it as possible to give you a more accurate reading of the water temp in the motor.
  11. #30
    Nov 2013
    QLD
    How did you put it in the thermostat??
