Page 466 of 1467 FirstFirst ... 464465466467468 ... LastLast
Results 4,651 to 4,660 of 14662
  1. #4651
    Looking at these photos it looks like you have 9 solar panels, you must use a lot of power.
    Thats how Cuppa gets his pocket money.
    Plugs in to the Grid and charges the power mob for Peak Load augmentation rates.
  2. The Following User Says Thank You to the evil twin For This Useful Post:
    NissanGQ4.2 (1st January 2015)
  3. #4652
    Expert Agronaught's Avatar
    Sydney, NSW
    Crap. Realised this morning that the patrol has a definite lean to the drivers side, at a guess the springs have started to sag. I guess I'm up for a new 2" lift kit just after chrissy.
    Maybe I should get airbags added while I'm at it for towing.
    J.
  4. #4653
    Quote Originally Posted by Agronaught View Post
    J.
    Upgrade time.
    I love the rear air bags in mine. Helps a lot when towing
    Sydney, NSW
    Upgrade time.
    Yeh, just bad timing but I guess it always is.
    I'll probably go the old man emu and get bags iinstalled at the same time. The existing lift was installed by the prior owner using an Iron Man foam cell kit, and from the looks of it caster correction was never installed. I also put my back out recently so I'm not currently up to crawling under the car to do it myself.
    J.
  6. #4655
    178 Post(s)
    Nah, ya can’t count! You’ve counted the same ones twice (they were in different places when I took the photos - I wouldn’t set them up on the ground facing in different directions) & you missed the one on the cab roof! I have 6 all up - a total of 425w, plus another 100w one I scored with the Tvan which I haven’t used to date. Once the RTT comes off the roof space will be filled with as many of them as I can fit in it’s place.
  7. #4656
    J.
    Not good with the back Argro, hope it comes good
  8. #4657
    .......... TPC's Avatar
    63 Post(s)
    It was all trick photography then, I thought you had taken the photos at the same time from different sides.
    I only have 160w and can get away with that with extended stays but have to keep swapping over between charging car and camper.
  9. #4658
    Sep 2011
    adelaide
    18 Post(s)
    Happy New Year All (sorry wrong thread )
    Cuppa can you fit the hatch 180deg around, or do what a mate has done with his 240 volt power cord and fit an alarm to the lock
    Just need a micro switch and power it up when you plug the van to the truck.
  10. #4659
    178 Post(s)
    I’ve heard the latest ones are having their hatches fitted with the hingg at the front. This would certainly make what happened to our very unlikely, but apparently it reduces airflow inside between the two hatches & also make cracking the hatch open a bit in the rain prone to letting water in. Haven’t decided which way round to fit a replacement yet. Not sure about an electric alrm, the wires could be a hassle, but we definitely need some sort of check system.
  11. #4660
    GET F@#*3D!!! never heard of such a thing
    You know what I thought lol
