Results 1 to 10 of 13
Thread: GUIV Front drivers side clunk?
    Mar 2013
    Gday all. After some more help. My GUIV has just developed a clunk in the front right. I cant seem to find anything out of order and only happens when turning and bouncing. It gives a perfect road test with no vibration. It is a pretty unnerving noise. Any help greatly appreciated. Phil
    Patrol Guru TimE's Avatar
    Canberra
    Sway bar bushes? That is what it was on mine.
  3. The Following User Says Thank You to TimE For This Useful Post:
    ptcb (27th December 2014)
    Check bolt tension in the radius arm bushes.
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Mar 2013
    Thanks fellas, forgot to mention that I just had ARB put a full 2"lift kit in including caster bushes. I will check these now as my bump stops fell out shortly after installation.
    Take it back to ARB, which outlet was it?
    Mar 2013
    ARB Hobart, Very poor Service and stuff all care.
    Quote Originally Posted by ptcb View Post
    I'm guessing there will be no rubber spring hats on top of the front springs....
    FNQGU (29th December 2014)
  11. #8
    Mar 2013
    No Mark there isn't. Nor is there any on the bottom. Should there be. If so where can I get some
  12. #9
    Legendary happygu's Avatar
    There are only rubber noise dampers at the top of the springs, and nothing at the bottom.
    The top rubbers are hard to see up inside the spring perch, but should be there.
    I added a flat 8mm Poly Spacer at the bottom of the passenger front spring, as this is usually the one that makes the most noise.
    Mic
  13. The Following User Says Thank You to happygu For This Useful Post:
    ptcb (29th December 2014)
  14. #10
    Yeah there should be on the top of the front springs. As mic said they will be hard to see. If there is none there I bet you that's where the noise is from. If you need some, you can get OEM ones or get on evil bay and search for spring spacers for patrol.
    You might be able to get your fingers up through the spring coils and inside the spring and feel for the rubber.
  15. The Following User Says Thank You to mudski For This Useful Post:
