Results 1 to 10 of 49
Thread: GU ZD30 Cranking but wont Run
Threaded View
  1. #3
    177 Post(s)
    This would have nothing to do with the sub tank.
    So If i understood this correctly... Fuel flows steady on the OUT line of the filter, but not at injector?
    This has the injector pump symptoms. Do you have access to a code reader like Scangauge or something? If not I'd head to super cheap, they charge a small fee to plug their device in and read for any codes. I'd start here, and could give you a heads up as to where it's gone pear shaped.
  2. The Following User Says Thank You to Hodge For This Useful Post:
    Danjo (22nd December 2014)
