Page 444 of 1057 FirstFirst ... 442443444445446 ... LastLast
Results 4,431 to 4,440 of 10566
  1. #4431
    Germany and NZ
    I replaced the battery in my GQ and took it for its WOF ( NZ Roadworthy) just gotta get rego and its all legal again, also bought complete another one as a spares reservoir and to kep the other one company when I am away at work, which should be getting driven up to me at the weekend.
  2. #4432
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Yep this happened..
    Ready for the 15mm replacement spaces for the springs cause rubber ones are stuffed, and dropping the radius arms off in the morning too get the castor correction fitted
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  3. #4433
    You shouldn't need castor correction bushes mate for a 2inch lift. I'd be going drop boxes if anything. Edit : Your not drinking on the job mate are you? Lol
  4. #4434
    Oct 2010
    Tatura VIC
    Castor correction bushes came with the lift kit, and they are rubber ones so might as well use them. It's only a 2" lift so I thought drop boxes might be abit too much castor. It drives fine as it is but a little bit floaty so thought I would fit them too make it drive abit nicer when the Mrs drives is (yes I let her drive it) haha
    Yes I might also have enjoyed a beverage whilst doing so lol
    Apprentice Sparky
  5. The Following 2 Users Say Thank You to big_fletch For This Useful Post:
    mudski (11th December 2014), Stropp (10th December 2014)
  6. #4435
    Yes the drop boxes would be a bit much hey. Reckon it might have been a better option thats all. As I haven't heard anything good about using castor correction bushes. Apart from doing what they are designed to do. Lol They just wear out prematurely. It will be interesting to see the difference the bushes make though with the steering.
  7. #4436
    Oct 2010
    Tatura VIC
    Got the arms back in and can see it sits on a better angle with the swivel hubs. Will see how it drives once I get it all back together, and how long the bushes last. They cost me nothing too put in except time so if they wear out quick I'll look at another option. Spends alot of its time on the blacktop at the moment so should get a decent run out of them (fingers crossed)
    Apprentice Sparky
  8. The Following User Says Thank You to big_fletch For This Useful Post:
  9. #4437
    Patrol God Stropp's Avatar
    38 Post(s)
    just got the chassis and underneath stripped back with wire wheel to loosen the surface rust and shit buildup and then had it sprayed with penatrol and rust proofed, yearly check and touchup $40 which is very good.
    the bloke doing it said there was decent mix of beach and desert sand under it
  10. The Following User Says Thank You to Stropp For This Useful Post:
    nissannewby (12th December 2014)
  11. #4438
    Beginner Drew43's Avatar
    Installed a GME UHF and aerial into the ashtray hole. Looks mint! Need a 90 degree connector for the aerial cable to clear the ac ducting but...
    Also diagnosed a leaky clutch hose with some help from the blokes here.
  12. #4439
    What are you using to repaint the chassis? I'm thinking of doing the same. Using POR15 paint though.
  13. #4440
    38 Post(s)
    No they used some rustproofing paint on it and it's not black but a gold colour.
