Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 67
Thread: show us your remote winch solenoid location
    Oct 2011
    Essendon
    Remember Westy, you'll get decent voltage drop between solenoid and winch if you're mounting it under the hood and from experience there are time when you need to wring every last bit of performance from that winch. You will need to upgrade the cables if you do this.
    Seriously, mount it on the bar mate. I considered doing the whole under bonnet thing and just couldn't be arsed. I don't think there is a huge advantage in doing it that way.
    But that's just my opinion
    Sent from my iPhone using Forum Runner
  2. #12
    333 Post(s)
    What Solenoid are you running Kallen? If it is a Solid State then strip it out of the control box and mount it wherever you like. I had mine mounted to the inner guard under the Washer bottle and it worked fine there. They are sealed and fully water proof so dont worry about it getting wet or dirty.
    Voltage Drop is a problem so as close as possible. My Solenoid for the GU is mounted behind the bar as already stated above and i have mounted the hand controller plug sticking out he grill. i have an isolation switch under the bonnet which cuts power to the switching side of the solenoid via a relay.
    If your trying to mount a Warn control box with the 4 solenoids then bin it. buy a Solid State and be done with it.
  3. #13
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    There should be no increased voltage drop caused simply by having the solenoid closer to the battery. If the cable lengths are the same, the current will be identical regardless of where the solenoid is placed in the circuit.
    John
  4. The Following User Says Thank You to jff45 For This Useful Post:
    04OFF (8th December 2014)
  5. #14
    brisbane
    Mines mounted inside the bullbar and is a warn style with 4 solenoid and has been under water countless times with no issue to date(over 5 yrs).... Touch wood lol
  6. #15
    333 Post(s)
    Quote Originally Posted by megatexture View Post
    Touch Wood. They are a Dog of a thing for Sh1tting themselves just when you need them most.
  7. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    04OFF (8th December 2014), cgm (8th December 2014)
  8. #16
    brisbane
    Shut it lol your getting me paranoid lol
  9. #17
    Advanced Pokey's Avatar
    Mar 2014
    Tassie
    Mine was mounted to the winch until recently I went to use it and found it was full of gunk and stuffed so relocated the new one to the engine bay. 1418026348094.jpg
    I plan to live forever................going well so far
  10. #18
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Exactly my thoughts.
    Mine is in the exact same spot as Pokey has his ^, the other good thing about remote mounting the solenoid, is that you remove any cables with permanent 12V power going right to the very front of your car, in a accident situation, I didn't like the idea of a "unfused" heavy cable connected directly to the battery surrounded by metal.
  11. #19
    Brisbane,QLD
    12 Post(s)
    Don't worry Troy, you've actually got to "go" 4wdriving to get stuck and need a winch (bwahahahah !)
  12. #20
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Quote Originally Posted by 04OFF View Post
    Not true. Ive seen people stuck in all sorts of ridiculous situations. Mostly gutters
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
