Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Check engine light
    Nov 2014
    Adelaide
    Thanks for that threedogs I will up the boost and check relays , I just changed changed maf sensor bout half hr ago.
    I purchased a 2006 zd30 motor with a cracked number 3 piston that I'm building at the moment. Sourcing Pistons is a night mare trying to fing forged ones? Any info would be greatly appreciated.
  2. #12
    176 Post(s)
    If you have blocked the egr you will get the check engine light but you should get it sorted by doing the daws valve and boost T .
    I thought about mentioning this too, but I thought the engine light comes on only on the CRD, not Di, if you block the EGR. Somebody correct me if I'm wrong though.
  3. The Following User Says Thank You to Hodge For This Useful Post:
    Jacksiv (24th November 2014)
  4. #13
    Nov 2014
    Hi, I'm also new to the forum and the ZD30. I've had this once already, don't forget the check engine light on these is also a 'water in fuel' sensor, drain the water out of the fuel filter housing, it needs doing now and again on the ZD30.
    Donny1
  5. The Following 3 Users Say Thank You to Donny1 For This Useful Post:
    Avo (26th November 2014), Jacksiv (26th November 2014), threedogs (26th November 2014)
  6. #14
    476 Post(s)
    If you have a Super Cheap auto near by, they have the machine to tell you what the code is. I think it cost around $15 for them to plug it in. They can also clear the fault codes too. Blocking the EGR prior to fitting the Dawes and needle valve can cause over boost issue and this may have been the cause of the CEL coming on. Also AFAIK, the ECU has a internal battery, like a resistor or what ever they are called to hold power in the unit if the battery goes dead. I do believe you need to disconnect the battery for overnight at least for this to work. I could be wrong but I think I read it here somewhere about it.
    Yes its the CRD's where blocking the EGR the CEL will sometimes come on and show a fault of the EGR. In the DI's case its usually an overboost issue, hence the CEL coming on.
  8. #15
    Nov 2014
    Adelaide
    Just like to say thanks to everyone, it's been a day and a half so far with no engine light coming on.
    What I did , every thing everyone suggested, the problem was over boosting. Thanks again.
  9. The Following 3 Users Say Thank You to Jacksiv For This Useful Post:
    Avo (26th November 2014), mudski (27th November 2014), Stropp (27th November 2014)
  10. #16
    Patrol God Stropp's Avatar
    36 Post(s)
    Glad the forum could help mate
