Page 438 of 1057 FirstFirst ... 436437438439440 ... LastLast
Results 4,371 to 4,380 of 10566
  1. #4371
    Patrol Freak kevin07's Avatar
    georges hall
    coolant temp sensor
    changed the coolant temp sensor on the tb for the better
    13 y62 the beast that burbles
  2. #4372
    Patrol God Stropp's Avatar
    38 Post(s)
    Quote Originally Posted by Dazzalco View Post
    Have you got a photo of them and was if rear only or front as well ?
    no pic and only the rears, google them for an image.
  3. #4373
    Advanced Dazzalco's Avatar
    Oct 2013
    Perth
    When it comes back looking like that, it must have been a really good day
    Yep was a good day now need lift and bigger tyres
  4. #4374
    Ha. So do I.
  5. #4375
    fitting a volt meter for my Aux battery,
    FYI there is plenty of room right down the left side of the centre facia for switches and gauges
  6. #4376
    Expert Paule's Avatar
    Jan 2014
    Sandhurst
    Fitted up a Provent catch can. I went with the xd heater hose option, thanks to the guys on here for the idea it works a treat.
    03 ST-L auto, Dawes and needle valve, provent catch can, 3' exhaust. I want more than I got
  7. The Following 2 Users Say Thank You to Paule For This Useful Post:
    Hodge (30th November 2014), Stropp (29th November 2014)
  8. #4377
    brisbane
    Should have got a dual volt to keep an eye on what the alternator is up to. Or have you got one already fitted
  9. #4378
    Gave the shitter a service and found the turbo to dump pipe gasket is leaking. Fark!
  11. #4379
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    After installing the second hand engine two weeks ago, found that when you release the clutch it made a horrible grinding noise until the clutch plate grabbed 100%
    So, drop the gearbox and found the flywheel was scored.
    Got my original flywheel, cleaned it up and spent an hour on it with some wet and dry 1500 grit and WD40. Cleaned up really well.
    The pressure plate and clutch plate that came with the second hand engine are brand new so installed them on my original flywheel and put the gearbox back in.
    Now the GQ runs quietly and is ready for a blue slip.
    Woo Hoo!!
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
  12. The Following 2 Users Say Thank You to rkinsey For This Useful Post:
    cgm (1st December 2014), mudski (30th November 2014)
  13. #4380
    177 Post(s)
    Nothing on the patrol but I sold my original set of alloys, and was shocked to see who turned up at my door. Very very high public figure. In respect to his wishes not to be named, all I can see is he drives a very nice 4.2 !
