Results 1 to 10 of 11
Thread: EGR plate
    Gold Coast
    Question EGR plate
    I see four possible locations to fit an EGR plate: (1) On the rear of the exhaust manifold, (2) On the EGR valve housing inlet, (3) on the EGR valve housing outlet, and (4) on the inlet manifold --from the EGR valve housing outlet.
    So which is OK, which will create problems, and which will not "work"
    It seems to me the rear of the exhaust manifold makes sense--maybe heat issues??
    top of the EGR pipe, which would be your top LHS looking from the front
    Well its that on a Di motor
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Dr Gary (16th August 2014)
    Patrol Guru
    NT
    The two considerations are really easy of fitting, and ease of detection.
    Ill put a picture here of a blocking plate then
    you can see the same shape on top of your EGR plate
  6. The Following User Says Thank You to threedogs For This Useful Post:
    476 Post(s)
    Underneath the intercooler on the rhs of the motor you can see a silver cast alloy pipe come up and bolt to the manifold. This is the best spot. The lower spit you referred too, is easier to get to, having direct exhaust heat it will be harder to undo the nuts and a higher chance of braking them.
  9. #6
    You will see this shape
    This plate suits CRD
  10. #7
    Beginner Ozmerican's Avatar
    Jul 2013
    Is there a difference between CRD and TD30's. I've seen some with holes in them. Does it make a difference?
  11. #8
    Quote Originally Posted by Ozmerican View Post
    I think holes are put in on the CRD ones to help prevent throwing a fault code........ Hopefully someone with more knowledge than I can shed some light
  12. #9
    The hole stops the ECU from seeing an occasional P0401 EGR fault code but because it allows gas past it kinda negates the purpose of the blanking plate.
    Amongst the myriad of other handy things they do, a Scan gauge (or equivalent) will easily reset the code and the check engine light allowing you to run a full blanking plate.
    Scangauge is the first thing I would buy for a CRD.
    If nothing else they will show you exactly how much horseshit and urban myth there is on the www. regarding CRD ZD30's.
  13. The Following 4 Users Say Thank You to the evil twin For This Useful Post:
    Clunk (25th November 2014), mudski (2nd December 2014), Ozmerican (2nd December 2014), threedogs (25th November 2014)
  14. #10
    Jul 2013
    ET,
    thanks for the data at the meeting. Going to figure this out ifnit kills me..
