Results 31 to 40 of 40
Thread: after market bonnet scoop?
  1. #31
    Aug 2011
    River Heads Q
    4 Post(s)
    Mine isn't a.r.e but you can tell the difference, if you have a bullbar fitted chances are your scoop isn't working. blue tack some cotton and test.
    Mine has vanes directing air to front as well as rear of intercooler. intercooler works at say 60kph instead of STD 80 kph
    Agree with bulbar comment. With standard scoop and bulbar, front half of intercooler does not work as seen in attached photo.
  2. The Following User Says Thank You to Wizard52 For This Useful Post:
    threedogs (8th September 2014)
  3. #32
    Quote Originally Posted by Wizard52 View Post
    Agree 100% been saying this for ages, The GU was not designed to have a bulbar fitted it just negates to scoop.
    Thankfully the after market ppl have saved the day
  4. #33
    Expert Oldmate1's Avatar
    Mar 2013
    Brisbane. Wynnum West
    i have the arb delux bar and the bonnet protector sits higher than the bar don't see how my inter cooler is effected
  5. #34
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    Quote Originally Posted by Oldmate1 View Post
    I got stopped by the police last month and told to remove the fishing rod holders I had on my bullbar or next time he would defect my vehicle and fine me $300. I went to the RMS and asked for their opinion and they told me the same thing. The fishing rod holders aren't allowed to be past the edge of the bullbar or it's illegal.
    The law may be different in Qld. I have seen quite a few others around here with the same setup I had.
  6. #35
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by Patrol-Guy View Post
    I think you're ment to loosen them and spin them out the way when not in use.
    Hello from Under Down Under!
  7. #36
    Dec 2013
    NSW
    I did not know that.
  8. #37
    22 Post(s)
    Its not that they wernt designed for a bullbar, the scoop is poorly designed. The majority of the opening is taken up by slow moving turbulant air called a boundry layer, only a very small amount of faster flowing air can actually enter the scoop, all that because it is too low.
    96 GQ coil/Cab
    08 G6eT
  9. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    MEGOMONSTER (9th September 2014)
  10. #38
    brisbane
    They are also having to follow ADR requirements.
  11. #39
    Beginner Ozmerican's Avatar
    Jul 2013
    Is there link to take a look at the ARE scoops?
  12. #40
    Western suburbs of Melbourne
    11 Post(s)
    Quote Originally Posted by Ozmerican View Post
    http://www.are.com.au/Inter/topMountIntercoolers.htm
    Just scroll down to the scoop section.
  13. The Following 2 Users Say Thank You to MEGOMONSTER For This Useful Post:
    Kimbo63 (17th January 2016), Ozmerican (2nd December 2014)
