Page 437 of 1057 FirstFirst ... 435436437438439 ... LastLast
Results 4,361 to 4,370 of 10566
  1. #4361
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    RD28T engine installed and all buttoned up (99% anyway) Bonnet installed and fixed the Alt circuit fuse, 75a, short issue. Turns out that I had connected the loom correctly. It was the second hand alternator from the donor motor was the issue where the main positive cable bolts to the post on the alternator. This post is supposed to have a plastic insulator around it and this was broken. Swapped the Alt for my original which is intact and all now working.
    Only a few jobs to go:
    1. Install tensioner pulley, for the AC condenser, and belt
    2. Gas the AC system
    3. Install the repaired front grille
    4. Install the headlights and indicators
    5. Drop the gearbox and install a new clutch plate for the HD exedy clutch kit and ribbed flywheel. (The clutch plate that was on the donor motors gearbox doesn't fit the input shaft on my gearbox)
    6. Replace the clutch slave cylinder (One of the apprentices pushed the clutch in when it wasn't connected to the clutch fork and pushed the piston all the way out and blew the seals.)
    Too hot to work on it anymore. Will have to work on it in the evenings this week.
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
  2. The Following 2 Users Say Thank You to rkinsey For This Useful Post:
    mudnut (23rd November 2014), threedogs (23rd November 2014)
  3. #4362
    Expert Agronaught's Avatar
    Sydney, NSW
    Quote Originally Posted by Agronaught View Post
    Checked mine out the other day, the 3 of them are steel pipe and enter the guard void above the front left wheel. Have no idea what's on the end of them but figure they are high enough. Be interested to see what you find.
    Ok, found em. Not worth dicking with (IMHO) for 1-2 inches of clearance. If/when i get a snorkel I'll reconsider.
    J.
  4. #4363
    Oct 2010
    Old Bar, NSW
    J.
    Thought the same, depending on the fittings if any are on the end. Can not be bothered pulling it off for a look
    Macca
  5. #4364
    Patrol God Stropp's Avatar
    38 Post(s)
    Took the old girl for a spin to lane pool reserve with 20 other patrols from the western patrol club.
  6. The Following 3 Users Say Thank You to Stropp For This Useful Post:
    Clunk (24th November 2014), DX grunt (24th November 2014), katwoman (23rd November 2014)
  7. #4365
    Advanced Dazzalco's Avatar
    Oct 2013
    Perth
    Took it out to harvey area and Brunswick was a good day out
  8. The Following 6 Users Say Thank You to Dazzalco For This Useful Post:
    93patrol (24th November 2014), Clunk (24th November 2014), growler2058 (24th November 2014), katwoman (24th November 2014), Timbo15 (25th November 2014), TPC (24th November 2014)
  9. #4366
    38 Post(s)
    fitted the BOSS shock tower supports, easy fit design and feel a bit happier now with them in so the towers wont bend with the load i carry all the time.
  10. #4367
    Oct 2013
    Perth
    Have you got a photo of them and was if rear only or front as well ?
  11. #4368
    Quote Originally Posted by Dazzalco View Post
    When it comes back looking like that, it must have been a really good day
  12. #4369
    Gave it an oil /air/fuel filter change. Didn't think an air filter would make that much of a difference. Can't wait for the snorkel.
  13. #4370
    84 Post(s)
    Re-fitted the manual choke, using a hand throttle knob I picked up for $5.
    The locking feature wasn't working, so I pushed out the roll pin, measured the hole and drilled through the neck of the knob to fit a cotter pin.
    I have down this same mod to the original hand throttle when I first got the Old Trol.
    I would have fitted the choke to the other side of the dash where the ready-made hole is, but the cable wasn't long enough.
    I need to make a proper label too.
