Page 429 of 1463 FirstFirst ... 427428429430431 ... LastLast
Results 4,281 to 4,290 of 14621
  1. #4281
    Quote Originally Posted by Punderhead View Post
    Well another day at work another argument. I checked my payslip to find I was $250 short. Went to my boss and said wtf. Told me it's because of his missing battery drill and charger, replacement fee. I only use my own. Major argument over who lost it. I've gone home now. Told him I won't be coming back in till I get paid. Should be interesting as I'm supposed to be working tonight.
    remind them that it is illegal to take money out of your pay with out authourity from you..had it happen to me once..told them if it wasn't there by the end of the day I was seeking legal action...got paid before knock off
  2. The Following 2 Users Say Thank You to Avo For This Useful Post:
    Punderhead (19th November 2014), TPC (18th November 2014)
  3. #4282
    Apr 2013
    After stuffing around designing & welding up brackets to hold the door stops on the garage roller door so I could raise the opening by 100mm to accomodate the height of the TeaVan successfully it has pi**ed me off greatly to find that the fully rolled up door now sits at 2050mm off the floor. What is the height of the TeaVan I hear you ask....... 2050mm. Bugger.
    Think I’m going to try lifting the actual door on it’s brackets by 25mm. Local garage door joint advised only undo one u bolt at a time. Am off into town now to get some longer u bolts. Hope I’m not back here later whinging about a roller door that ‘let go’!
    take the door up cuppa...use rope or small ratchet straps to hold it rolled....let the u bolts off...the spindle will spin to neutral position....is ok...if you can get a hand to lift it down ..then lift it down...move the brackets up the desired height ..put door back on them and u bolts...leave straps on and rotate door about 2.5 turns to retension..if you have no motor then you have to use a weight on the floor and small rope to handle or something on door to stop it spinning back so you can take the straps off and pull door down....what are you doing about the guides and the lead in ?...I used to instal them...plus check how much of the door is left on the roller before you lift it too far....I have left half a foll on before but that is cutting fine
    the one thing wrong with middle age ...is knowing you will grow out of it !
  4. #4283
    .......... TPC's Avatar
    63 Post(s)
    As Possum said, they can not legally do that, in SA I would ring "Safework SA" to get advise, you should have an equivalent government department in QLD to contact.
  5. The Following User Says Thank You to TPC For This Useful Post:
  6. #4284
    Expert Agronaught's Avatar
    Sydney, NSW
    Competitions that require facebook...
  7. The Following 3 Users Say Thank You to Agronaught For This Useful Post:
    Bob (18th November 2014), jack (18th November 2014), mudski (18th November 2014)
  8. #4285
    Western suburbs of Melbourne
    11 Post(s)
    Facebook in General.
  9. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    93patrol (18th November 2014)
  10. #4286
    @ Cuppa why not let the air out of the campers tyres,
    or get smaller tyres when at home to move it around
  11. #4287
    not on it never will be or twitter or fat a gram or icloud what ever
    i will not use it ever
  12. #4288
    Sydney, NSW
    Never won a competition before... not likely to at this rate. A shame really as I'm in the market for an airbag kit.
  13. #4289
    Quote Originally Posted by Agronaught View Post
    Really if you want to enter that bad just create an account and don't use it, delete it when the comp is over
  14. #4290
    Sydney, NSW
    yeh... took 18 months to delete the account I used to have, not making that mistake twice
