Results 1 to 9 of 9
Thread: Exhaust/Turbo Guard
    Beginner Rexzilla's Avatar
    Nov 2011
    Thornlie WA
    Exhaust/Turbo Guard
    I have just had a 3" Manta exhaust fitted to my Patrol, just wondering what peoples thoughts are on refitting the OEM exhaust/turbo guard?
    Any Pro's, Cons?
    2008 3.0 GU Patrol Wagon auto, 2 inch lift kit, 3" exhaust, Tig Welded Intercooler, Snorkel, Steel winch bar-14,500lb winch, more to come
    2003 3.0 GU Patrol Wagon auto, 2 inch lift kit, Rancho shocks, 3" Manta exhaust, Tig Welded Intercooler, NADS, snorkel, dual batteries, Steel winch bar.
    Expert janderson's Avatar
    Bearii Vic
    when my 3'' exhaust was fitted the guard was not refitted or returned.
    1st G60 Then MQ Now GU
  3. The Following User Says Thank You to janderson For This Useful Post:
    Rexzilla (16th November 2014)
    Expert SG1's Avatar
    Sep 2014
    Gippsland, Vic
    The turbo heat shield makes a huge difference on heat and would think it should be fitted. I tried mine with out it fitted after putting a new exhaust on and the heat coming of the turbo was a lot, bit of a pita to put back on but trimmed it up a bit around the edges and ended up no probs, made a big difference in heat coming of the turbo.
    02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
  5. The Following User Says Thank You to SG1 For This Useful Post:
    Aug 2010
    adelaide
    if you have a second battery you need to put it back on as the heat will destroy the battery very quickly
    OH LEATHER IS NICE
    177 Post(s)
    Go for a good drive without the shield, let the turbo really warm up. Then pop your bonnet, the heat coming off it, will make your refit the guard quick smart. They are there for a reason. ANd especially what my third said, if there is a battery there, then it is a no brainer, otherwise it will cook it quickly.
    Rexzilla (17th November 2014)
  9. #6
    Nov 2011
    Thornlie WA
    Well after a bit of cutting and shutting I finally refitted the heat shield, what a prick of a thing to get in and out.
    Thanks for all the advice and comments, I run a second battery so I thought it might be wise.
  10. #7
    476 Post(s)
    Do you have ABS and rear air cond Rex? I don't on mine and there was no need to cut the shield. Although I feel like cutting it off as I need to replace the turbo to dump pipe gasket soon. What a biatch of a job this will be.
  11. #8
    Nov 2011
    Thornlie WA
    No Mark, none of that stuff on mine lol
  12. #9
    476 Post(s)
    I'd be putting it back on mate. Its there for a reason and a good one too. You just need to hold your tongue right as they are a bit tricky to put fit.
    SG1 (5th December 2014)
