Page 435 of 1057 FirstFirst ... 433434435436437 ... LastLast
Results 4,341 to 4,350 of 10565
  1. #4341
    Stage one of operation wash cars.......... step one, got the power washer out, crawled underneath the MightyGQ and blasted away, then on the the outside to wash off all the loose dust n dirt before getting the sponge out........ then coffee break
  2. #4342
    And check your escape route cause if the breaker bar slips you could be in a whole world of pain
    Use open hands and the correct technique and this can be greatly reduced.
  3. #4343
    Stage one of operation wash cars now complete............... one car down, two to go
  4. The Following User Says Thank You to Clunk For This Useful Post:
    Stropp (16th November 2014)
  5. #4344
    Was a very funny letter from a reader of 4WD monthly years ago, , for some reason
    he had the front wheel off his GQ and was sitting in the cavity with a hammer, what ever he hit it rebounded hitting his head.
    so he threw his head back hitting the inner guard bang then pushed his head forward hitting his forehead, which caused him to throw his head back you get the picture this continued till his brain stopped rattling and he came to a halt, He cracked a beer and PHSL
  6. The Following User Says Thank You to threedogs For This Useful Post:
    growler2058 (16th November 2014)
  7. #4345
    Stage 2 complete........ 2 down, 1 more to go but that will have to wait till later. Missus has "done her back in", so muggins here has to go get the food shop
  8. #4346
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    Motor in, loom all connected and running. Finally!
    Just a few more things to do. Replace the clutch slave cylinder (one of the apprentices that was helping me jumped in and pushed the clutch in, while the slave cylinder was not connected to the clutch fork, and this has the pushrod all the way out of the slave cylinder) replace the starter motor and alternator (The ones from the donor motor aren't much chop) install the 2" lifted springs from the donor. Install the bonnet , front grille and lights.
    After six months of the engine not running and sitting on my back porch, it fired up second go and no clouds of smoke and no leaks either! Not bad for an IT engineer.
    Thanks to Rust Nail and Todd for their assistance earlier this year and helping me pull my engine out.
    Woo Hoo! nearly ready for rego.
    https://www.facebook.com/video.php?v...13453317946836
    Cheers,
    Rob
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
  9. The Following User Says Thank You to rkinsey For This Useful Post:
    threedogs (16th November 2014)
  10. #4347
    Feb 2011
    Shed
    45 Post(s)
    Long bar and a heavy rubber mallet
  11. #4348
    Patrol Guru Rocket55's Avatar
    Sydney
    Extended the rear diff breather. Ran it up to the front. I went up the drivers side to stay away from the exhaust and cat converter with a rubber hose, is this what everyone else does. Just terminated it with a miniature in line fuel filter. I ran the hose behind the wiper motor, this gave me a nice radius on the hose to allow the breath to point back tow at the ground.
    Might do the front 3 tonight, they're pretty high as it is, so not as much to gain and therefore lower in the priority list..
    Cheers Rod
    My Build 2005 TD42TI
  12. #4349
    Sydney
    Finished off my rear door table on the weekend.
    Pretty happy with how it came up
    Also extended my rear diff breather last night, might do the the other 3 tonight but they're pretty high up anyway.
    Cheers Rod
  13. The Following 3 Users Say Thank You to Rocket55 For This Useful Post:
    cgm (19th November 2014), katwoman (20th November 2014), threedogs (19th November 2014)
  14. #4350
    Patrol God Stropp's Avatar
    38 Post(s)
    Hooked up the led lights today and fitted some bilstien shocks. Pretty happy with the LEDs.
  15. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    katwoman (22nd November 2014), threedogs (22nd November 2014)
