Page 434 of 1057 FirstFirst ... 432433434435436 ... LastLast
Results 4,331 to 4,340 of 10566
  1. #4331
    Jan 2013
    Shimmed and locked my diffs
  2. The Following User Says Thank You to Dales300exc For This Useful Post:
    cgm (15th November 2014)
  3. #4332
    Patrol Guru Rocket55's Avatar
    Sydney
    Installed a cargo barrier and finished my barn door fold down table today.
  4. #4333
    Got inspired, took some good advice went and bought all new oil ie diffs, transfer case and gear box climbed under armed with my best socket set cannot remove a single filler plug. I was told on this forum I should remove filler before i drain
    Thank god I read the threads or I would now have an empty diff and no way of putting the oil back in.
    Starting to think I may have to pay a mechanic for this one dont want to do any damage?
  5. #4334
    How much force can you use on the filler plug?
    Is it worth getting an impact wrench , air or cordless
    or do i get get the mash hammer and go to town on the socket handel ?
  6. #4335
    Feb 2011
    Shed
    45 Post(s)
    As much as is needed. The drain plug will probably be as hard. I used an electric impact gun to get the bastards out
  7. #4336
    Jan 2013
    Would not recommend impact equipment on fill/drain plugs. The rattling has a tendancy to round and then it makes the job harder. A good crack on the plug with a hammer should shock it enough.
    Short of that get more leverage. Jack the car higher so you can get more swing. Use a breaker bar.
    Unsure what vehicle you have, but assuming its just ya standard 1/2" plugs then make sure any mud is scraped out so a good purchase is acheived.
  8. #4337
    Advanced Snow Patrol's Avatar
    Jul 2014
    Snowy Mountains NSW
    Got my Dawes setup just right..... very happy.......
    2008 Patrol 3.0L 2" Raw Nitro Lift, Polyair airbags, Airflow snorkel, Drawers, UHF, Dual battery system and cage scavenged from my Prado Alloy roof basket from the chookyard. Boost and EGT gauges and NADS
    1980 MQ Ute (nearly forgot the indestructible farm Ute)
  9. The Following 2 Users Say Thank You to Snow Patrol For This Useful Post:
    Stropp (16th November 2014), threedogs (16th November 2014)
  10. #4338
    And check your escape route cause if the breaker bar slips you could be in a whole world of pain
  11. #4339
    started on my 20 ltr water tank. should work well IMO
    will use a 3/4 ball valve as a tap better flow,
    fill is via the top
  12. #4340
    Oct 2014
    Sedgwick Victoria
    Stuck a light bar on the roof rack
  13. The Following 2 Users Say Thank You to Semmo For This Useful Post:
    threedogs (16th November 2014), Timbo15 (16th November 2014)
