Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 99 GU 4.5 AUTO low range temps
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    X3 on the thermostat, I think they are about $60 for a tb45, but at least you know it works, and opens at the right temp.
  2. #12
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    The most useless instrument in the Patrol has to be the temp gauge. Anything not in the red is normal.
    You need to get an Ecutalk and see exactly how your engine is behaving. By the time you pay for rad clean, fan clutch & thermostat, which might or might not be necessary, you won't be far off the cost of the Ecutalk.
    Get a temp gauge on your auto trans and see if you're not pumping over 100 C through the bottom of your rad in those conditions..
    John
  3. #13
    X 2 with using an OE thermostat, as I have copped a bad after market one, before. Since then, I test any new thermostat I fit, by placing it in a pot of boiling water. It doesn't take too long, for the thermostat to open.
    That's my way of checking if it's working or not.
  4. #14
    Beginner Hilux's Avatar
    Jul 2012
    4 Post(s)
    Well after Replacing Thermostat, Water pump and Clutch Fan Turned out that it was the Radiator. The water pump had a leak im guessing the last owner put some kind of chemi-weld to stop the water pump leak and it blocked up the radiator. Now I can Low range in luxury with the aircon flat out. leave idling in 34 degrees outside and the temp hasent moved past halfway. For some reason seems to run a little cooler with Gas rather than petrol. Thanks for everyone's input im pretty sure the clutch fan was gone also but at least i have the whole cooling system done.
  5. The Following User Says Thank You to Hilux For This Useful Post:
    04OFF (24th November 2014)
