Page 428 of 1057 FirstFirst ... 426427428429430 ... LastLast
Results 4,271 to 4,280 of 10566
  1. #4271
    http://www.ebay.com.au/itm/680-Air-c...item19eaf1f4ec
    Had one of this lying around so thought Id mount it to the cargo barrier, I'll use it to run an air horn, and later a front Prolocker
  2. #4272
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Did more diff bracing today. Son is asleep at the moment and need to do some grinding, so on hold for the moment.
    IMO and should be taken with a grain of salt.
  3. The Following User Says Thank You to Parksy For This Useful Post:
    threedogs (9th November 2014)
  4. #4273
    Quote Originally Posted by Parksy View Post
    did you slice a piece of 50mm x 25mm x 2.5 RHS to laminate it?
  5. #4274
    Jan 2013
    Nowra NSW
    5 Post(s)
    No I ended up with the kit from road runner off-road. Also added my own touches by improving the radius arm brackets.
  6. #4275
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Fitted the override switch for my dual battery setup, blew a fuse and had to go to 4 shops to find another one.... On the plus side, that's the dual batteries totally sorted! Waited for the heat to die down a bit, (working in the sun on the driveway in 37 degree heat is not fun), then started pulling stuff off so I could do the carby plate mod, found out the nuts were seized, and the light was going, so that'll have to be next weekend.
  7. #4276
    Patrol Guru Rocket55's Avatar
    Sydney
    Fitted up my snorkel today. What a PITA, but worth it in the end.
    Cheers Rod
    My Build 2005 TD42TI
  8. #4277
    Nov 2010
    Getting a life...
    38 Post(s)
    Booked in to get shockers fixed ! And ordered new springs. No more saggy bums.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  9. #4278
    Feb 2011
    Shed
    45 Post(s)
    Cleaned the poop off my seat after yesterdays lil fright
  10. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    Chubba (10th November 2014), Clunk (10th November 2014)
  11. #4279
    Hardcore 2TROLLFAM's Avatar
    Nov 2011
    Chuwar - Ipswich - QLD
    I put my baby on a truck today - he was off to Banyo for his "work" tomorrow
    Sent from my iPhone using Forum Runner
    NISSANS Rulz .... "Amelia" the 2006 4.2ltr Patrol Ute & "Seamus" the 2008 3ltr Patrol Wagon
  12. #4280
    Quote Originally Posted by 2TROLLFAM View Post
    Jeez! Whats he getting now!
    2TROLLFAM (10th November 2014)
