Page 4 of 19 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 187
Thread: DIY CV and Swivel Hub Rebuild Thread
  1. #31
    Expert 89GQ's Avatar
    Adelaide South Aus.
    Quote Originally Posted by tallman View Post
    "The Bearing Driver kit Less than $50 and Highly recommend one of these to everyone!!)"
    Where the hell did you get that price from?..lol cant find one on ebay for less than $90
    Heres one
    http://www.ebay.com.au/itm/231378144...84.m1497.l2649
    89 GQ TD 42
  2. The Following User Says Thank You to 89GQ For This Useful Post:
    MudRunnerTD (9th November 2014)
  3. #32
    Adelaide South Aus.
    What an awesome how to MudRunner, great detail and pics. I been putting this off for a while now , and now am more than confident to tackle it after reading this.
    Thanks heaps..
    89 GQ TD 42
  4. The Following User Says Thank You to 89GQ For This Useful Post:
  5. #33
    Adelaide South Aus.
    Question with the scraper seal, do you put the joins up top,opposite each other, anywhere ???? Cheers
    89 GQ TD 42
  6. #34
    Cheers mate, glad you have found it helpful.. Yes i fit the join at the top but should not really matter.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    89GQ (10th November 2014)
  8. #35
    Germany and NZ
    Hi,
    I stripped my front hubs today and found no circlips at all.
    My truck has run well on and off road since 2008 when I got it so my question is what do they actually do and what size are they as I will have to go to an engineering supply place to get them if someone could post a photo of one and a size this would be very helpful.
  9. #36
    Check inside your locking hubs. Do you have auto or manual hubs mate? Check embedded in the grease.
    Note there are 2 groove on the axle. The circlip will fit into that groove. The inside groove is used when you have auto hubs and the groove near the end of the axle is used when you have manual hubs. Put a vernier on it
  10. #37
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    If you pull the spindle off, it has a seal on the inside of it. The cv is hard up against this, if the circlip is installed. Without the circlip, this could cause a transfer of cv grease through the spindle and into the hubs themselves.
    IMO and should be taken with a grain of salt.
  11. #38
    Germany and NZ
    Hi,
    I am out in the boonies and don't have a vernier, I can use a bit of string and work out the diameter of the groove that way. My closest engineering supplies mob is 50 km away.
    Is it a circlip like you would find in a gearbox or does it have two holes in it for the pliers to go in?
    I have manual hubs and have felt around inside the hub and can't feel anything.
    My hub seals are showing signs of weeping this year for the first time ever, is the lack of circlips likely to be the main culprit?
    It was the infrequent wobble at 60 km that started me looking at the wheel bearings.
  12. #39
    Jan 2013
    Nowra NSW
    5 Post(s)
  13. The Following User Says Thank You to Parksy For This Useful Post:
    MudRunnerTD (16th December 2014)
  14. #40
    Germany and NZ
    Thanks, One real annoyance is I bought a rebuild kit and all I can see it doesn't have is these clips.
