Note: this post is in response to other posts moved to another location from here ==>
http://www.nissanpatrol.com.au/forum...ervice-centres
I struggle to understand, what is it exactly you are after?
It is actually a good thing that you don't have to visit Nissan. Those morons struggle to figure out what Patrol and Y61 have in common.
You do the service work yourself and have a mechanic to do more complex work so what do you want Nissan st$alers for?
They must do safety recalls, indeed they'd track you down through motor registrar if need be otherwise Nissan AU will be in a lot of trouble if that was a cause of an accident and dealer refused to carry out the recall because you have 3" exhaust and 2" lift kit.
If there is a recall for EGR valve functionality would you take it back?
In any case what recalls are you sweating about on 10+ years old vehicle?
If you are concerned about possible airbag recall than that has nothing to do with engine mods.
Regards
