yes it will have a SWL of 50kg max,, it uses an ATV winch motor 12v it was very easy to over engineer using only rated fittings
When i have the final design I'll get it tested, From memory they will lift 50kg and hold it for 4 hours or so
if it hasnt sagged at all it passes but a little way off yet, RRP will be around $750,
I will be using 6mm Dyneema instead of 3mm and the 12v ATV motor is rated at 1500KG so we'll see what the NATA ppl say
