Page 23 of 28 FirstFirst ... 2122232425 ... LastLast
Results 221 to 230 of 277
Thread: Growlers' GU DX
  1. #221
    Do the earlier series 3 tail lights fit yours. then you can have decent reverse lights in conjuction with a reverse light
    on a stand if you go that way
  2. #222
    Feb 2011
    Shed
    45 Post(s)
    Dunno
    I think down the track I'll get the falsies working though
  3. #223
    Yeah but that only gives you brake lights doesn't it, not sure
    I've seen some done with the indicators and brake like working,
    but I went for the reverse light, awesome in the bush at night
  4. #224
    Feb 2011
    Shed
    45 Post(s)
    I'll have to check but i rekon the reverse lights do work in the tail light not the bumper light???
  5. #225
    Legendary happygu's Avatar
    The extra lights are very handy from a safety perspective, and look good too.....
    Reverse Light is only in the body, but you only have drivers side light from the factory.
    When the time comes, you can purchase the aftermarket ones with LED Lights or normal globes, and with a little bit of wiring, you have Stop/Tail, Reverse and Indicators in the body on both sides.
    From what I can remember, Drivers side was plug and play, but you need to add stop and tail from below, and the passenger side requires a wire from the other side for reverse, and the rest from below.
    I had a couple of nice wire grommets perfect for the job, and there is a flat spot underneath on the inside panel which looks like it was made for a wiring loom but there is no hole ( lie down and look from the chassis rail towards the inside body panel and it will be obvious. I just drilled the hole, painted the edges and inserted grommet with wiring, then straight across to the bumper lights ( and dont freak out too much about the miniscule factory wiring you will find. I just bared back the insulation where I could, wrapped the new wire around, soldered and taped. All good.
    Mic
  6. The Following 2 Users Say Thank You to happygu For This Useful Post:
    growler2058 (5th November 2014), threedogs (5th November 2014)
  7. #226
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by happygu View Post
    Mic
    Cheers mate. I don't like doing auto elec but that sounds easy enough
  8. #227
    Hardcore 2TROLLFAM's Avatar
    Nov 2011
    Chuwar - Ipswich - QLD
    Bigger I forgot about you needing the tongue !!
    LMFAO
    Sent from my iPhone using Forum Runner
    NISSANS Rulz .... "Amelia" the 2006 4.2ltr Patrol Ute & "Seamus" the 2008 3ltr Patrol Wagon
  9. The Following User Says Thank You to 2TROLLFAM For This Useful Post:
    growler2058 (7th November 2014)
  10. #228
    176 Post(s)
    Hows this Johnno hahahahahhahaa
    What’d shave ya feet for?
  11. #229
    Feb 2011
    Shed
    45 Post(s)
    To clear up the athletes foot mate
  12. The Following User Says Thank You to growler2058 For This Useful Post:
    Clunk (7th November 2014)
  13. #230
    Feb 2011
    Shed
    45 Post(s)
    Fitted up the scan gauge today and my breather extensions. The tnsfr case and gearbox looked to be an absolute bastard to get to. So I've connected the extensions to the original rubber breathers fitted a treat
  14. The Following 5 Users Say Thank You to growler2058 For This Useful Post:
    Bob (13th November 2014), cgm (12th November 2014), Clunk (12th November 2014), rusty_nail (13th November 2014), Stropp (12th November 2014)
