Page 60 of 570 FirstFirst ... 5859606162 ... LastLast
Results 591 to 600 of 5693
  1. #591
    brisbane
    Could just use cooking oil to if need be
    Jack oil is like water I'd be worried the cooking oil would be too thick and not flow freely enough when retracting
  2. #592
    Aug 2011
    Oakland OREGON, but in Aus on holiday
    Ordered UFI 18G Turbo kit ....
    I knew I should have gotten the 3 pod window column housing (EGT, Boost and direct read water temp)
    Upgrade the clutch and the end of the upgrade list is now at least on the horizon ..
    2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
  3. #593
    Patrol God Stropp's Avatar
    38 Post(s)
    Quote Originally Posted by HuskyInAuz View Post
    you will be very happy with that kit, but as for nearly finished lol always more to do or want.
  4. The Following User Says Thank You to Stropp For This Useful Post:
    HuskyInAuz (5th November 2014)
  5. #594
    Quote Originally Posted by megatexture View Post
    Cooking oil is very runny and will work fine, Had it in my trolley jack for years no probs, but at the time had no oil when it was low.
    Since brought another trolley jack, but handy to know if you get stuck somewhere
  6. #595
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Bought some more dynamat and high density closed cell foam insulation. Hopefully it arrives before the weekend. Planning on ripping out the roof lining and sound proofing it. Will also take the opportunity to properly fill the sills with penetrol. Then when I can be bothered, I'll make a new roof liner that I can just unbolt easily.
    IMO and should be taken with a grain of salt.
  7. #596
    Quote Originally Posted by Parksy View Post
    I take it you can have the Patrol off the road for a few days, good time to run some spare wires for any future mod you may think of.
    Looking forward to your report, as I'd love to sound proof mine as well,
    In YO do you think dyna matting the roof will make it much quieter?
    Is 36 squ ft enough or do you need more ,this stuff is expensive
    Floor area , doors /roof.
    With my other 4x4 I just shoved some acoustic batts down the 1/4 panels
    worked a treat
  8. #597
    Jan 2013
    Nowra NSW
    5 Post(s)
    The stuff is expensive and the majority of my floor and doors is already done. 36square feet will be more than enough to do the entire roof section and I reckon it will make a massive difference, especially when combined with the closed cell foam. There isn't much in terms of sound proofing in the roof. When I did just the firewall the difference in engine noise was amazing. Well worth ripping the dash out and doing it properly.
  9. #598
    Aug 2011
    LOL .. well wife thinks the end of the list should be near for the moment
  10. The Following User Says Thank You to HuskyInAuz For This Useful Post:
    Stropp (5th November 2014)
  11. #599
    Bought this on Friday. Just need a shed I can really call my own and make it a permanent fixing.
  12. #600
    476 Post(s)
    rda slotted and dimpled front brake rotors and pads, has needed doing for a bit but have bit the bullet now.
    I just did the same mate but also bought extended braided lines, the two centre ones and the four shorter ones to the wheels. Wow! I now have brakes!!!
