Results 1 to 8 of 8
Thread: Mudflaps
    Advanced bindi's Avatar
    Apr 2014
    Gippsland
    Mudflaps
    G'day all,
    Now i have my OME lift fitted, I want to fit some larger mudflaps so that i'm not flinging rocks at the caravan etc.
    Where do you reckon is the best place to get some good thick flaps from, or good rubber which I can trim to size?
    I am thinking just remove existing nissan flaps (which are small anyhow) and refit new bigger ones?
    cheers all,
    Mark
    2012 GU8 ST CRD Platinum Silver with Tints, Factory Bar, IPFs, Snorkel, UHF, Maxtrax, Rated Recovery points front/rear, In dash Nav, Scangauge2, Ally Roof Rack, OME 2" Lift
    Perth WA
    63 Post(s)
    Get some convey belting, I had over 25 metres of it but has all gone to friends
    you can buy a kit that clamps around your reece hitch(if you had one)can't for the life of me think of it's name.
    Apr 2013
    buy truck mudflaps...they are cheap and you can just cut them to shape and they come in different widths
    the one thing wrong with middle age ...is knowing you will grow out of it !
  5. The Following User Says Thank You to menace 2 For This Useful Post:
    bindi (18th November 2014)
    brisbane
    I like the idea of clamp on ones also for towing but I'd replace the factory ones also, they just get ripped off because they are too stiff
    http://rvtowingsolutions.com.au/prod...-tamers#rtinfo
    You could diy this also with a bolt on option there are a few in google images
  7. The Following 3 Users Say Thank You to megatexture For This Useful Post:
    Avo (1st November 2014), bindi (18th November 2014), Stropp (1st November 2014)
    I would get an "Apron" made for the front of your van,across the drawbar
    also think about protection for your rear windows.
    Maybe some perspex cut to shape using suction cups might work.
    Plenty of products available to do both.
    If fitting larger mudflaps use chains to hold them in place
  10. #7
    Feb 2011
    Shed
    45 Post(s)
    I had big CAT flaps I got from ebay
  11. #8
    Patrol God Stropp's Avatar
    38 Post(s)
    thats because you are a pussy
  12. The Following User Says Thank You to Stropp For This Useful Post:
    Maxhead (2nd November 2014)
