you don't need to drill metal, just drill a 3/16 (or 4.5mm) hole in the underside of the plastic hinge cover. It pops off easy enough and you won't even see the hole. I threaded my power cable through the mount tube, out the bottom and it it hides behind the wheel, goes through the small hole in the plastic hinge cover, threads through the harness rubber (along with rest of wires) and then just ran the cable under the carpet to the front for power, with a neat little round switch on the middle console. Easy!
I hate drilling metal, it's just bad!
