Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Which clutch to buy?
    Oct 2010
    Old Bar, NSW
    My clutch is starting to play up, I think.
    It did slip once about month ago when I gave it a bit to get going in H1 when I should have been in L2 or 3.
    It feels like its slipping and grabbing once or twice when I start moving particularly noticeable when turning as well, the other day it had a vibration and the engine was moving like something was off centre and out of balance.
    It drives OK, doesn't slip but I think that is where the problem is.
    So what to get for it?
    It's a 4.2TDi 2005 year model.
    Any reviews on what to install and cost of the parts would be a help.
    Thanks in advance
    Macca
    There are a few options available.
    Exedy safari tuff
    NPC 6x6
    4terrain.
    Each of these for your application will do the job well and pedal feel won't change. Do a little shopping around to see who can give you the best price on those options.
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    macca (30th October 2014)
    Oct 2010
    Old Bar, NSW
    What are you using?
    Macca
    Exedy safari tuff
    NPC 6x6
    4terrain.
    I have the safari tuff and was told the pedal feel would be a nightmare but only noticed it slightly for a week and its such a minuet difference but highly recommended for towing and reliability.
  6. The Following User Says Thank You to AB For This Useful Post:
    What are you using?
    I currently have the exedy safari tuff installed in mine.
    I have also recently fitted a NPC 6x6 to a mates car I built for him with a td42 and it holds well at just over 200hp.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
  9. #6
    Oct 2010
    Old Bar, NSW
    Surprised we've had no other brands spoken about. What about OEM? Safari talk of more clamping force, that is a good thing?.
    Macca
  10. #7
    For the cost the above options are the go over oem. They all have a higher clamp pressure than standard. The npc uses the same clutch disc as the exedy. I am not aware of which clutch disc the 4terrain use.
  11. #8
    Oct 2010
    Old Bar, NSW
    Thanks mate, will probably head this way. A mates son has had a lot to do with skylines etc and found the exedy were not up to the task in those cars suggested I do some research on the internet. Seems the 4x4 ones are better.
    Macca
  12. #9
    Oct 2010
    Old Bar, NSW
    I can not find clutches on Patrol-a-part, am I missing something?
    Macca
  13. #10
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Ebay is your friend, in car and truck parts.
    Item no. 290588654168 is a 4 terrain clutch.
    [SIGPIC]
  14. The Following User Says Thank You to GUtsy ute For This Useful Post:
    macca (1st November 2014)
