Hey all,
The old girl GQ needs new suspension bushes and I was wondering if this has them all or if i need to get more not contained in the kit http://www.ebay.com.au/itm/Full-Susp...3D330839511333
Also whats the best way to do this?
Hey all,
Yes mate that has everything you need, I would suggest that you consider spending the extra money for genuine bushes instead of those aftermarket ones though. Genuine are higher quality and will last longer and perform better.
GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
I second that. Whiteline bushes are good for your panhards. If your car has a lift, make sure you get castor correction bushes for the radius arms
Not a fan of drop radius arms personally, the only thing that really corrects a radius arm geometry (and castor angle) after a suspension lift is drop boxes. The reasoning behind this is that it brings the rear of the radius arm down to match the amount you have lowered the front diff.
mudnut (30th October 2014)
GO HARD OR GO HOME!!!
My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
WARNING: Towballs used in a recovery can and DO KILL people!!!
Crate (30th October 2014)
