Page 421 of 1057 FirstFirst ... 419420421422423 ... LastLast
Results 4,201 to 4,210 of 10561
  1. #4201
    476 Post(s)
    I worked out an easy way of getting the OEM hubs apart and back together. First shot I removed the small spring locking washer when the entire hub components were in the hub. Cleaned it up and had a hell of a time putting it all back together whilst trying to compress the large spring down and hold the top plate down. I needed four hands... I remove the other hub and turned it upside down, with the gears facing towards the bench and gave it a good tap and the entire locking section came out in one piece. So there was no need to pull it apart like I did...
    I almost bought some AVM hubs but I don't like the idea of those small screws in the cap as last time two were jammed in so bad, I went through four torx bits before I gave up and just broke the thing off. Maybe if they had some never seize of the tapered section of the screw it would have been a different story...
    Note. I had already removed the plate that makes these hubs auto a while ago, so now they are just full manual hubs...
    Stropp (28th October 2014)
  3. #4202
    Edit : had a coupla beers and a glass of red and went back out and got the hub together.
    Amazing what you can achieve after a some refreshments .
  4. #4203
    Patrol Guru Rocket55's Avatar
    Sydney
    Threw a couple of 30mm spacers in the front to temporarily give me back so e height I lost after the dual battery and winch went in and a 15mm set in the back. Found out my shock are kaput :-(
    Cheers Rod
    My Build 2005 TD42TI
  5. #4204
    Quote Originally Posted by Rocket55 View Post
    nice and bouncy ride is it, I have some 15mm spacers I want to fit as the OE ones are long gone
  6. #4205
    Sydney
    Yeah it wollows around a bit and generally has bugger all body control. It just crashes through bumps as opposed to trying to deal with them. Disappointing thing is, it's only done 52,000km. I can compress all 4 shocks with one hand simply by leaning in from outside the car and pushing it up...
    Cheers Rod
  7. #4206
    Western suburbs of Melbourne
    11 Post(s)
    Had to fix my trailer plug, as I nearly ripped to off the last time we were at Wombat.
    And fixed my Stebel air horn, it seems something was stuck internally.
    Blew it out with compressed air and gently tapping at it.
  8. #4207
    476 Post(s)
    My Stebel sounds like a muffled duck. Been like that since new. Been meaning to find out why...
  9. #4208
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    Not quite today but on Sunday..
    Installed new HD Adjustable Front + Rear panhard rods, HD Adjustable draglink and a Tough Dog RTC steering dampener.
    Pretty happy with it all, it's completely eliminated my wobbles between 60-100km/h.
    Next thing is HD +16mm lower control arms then some 4" springs.
    Anyone looking for a set of less than 1 year old 3" Dobinson springs?
    '96 GQ TD42t
  10. #4209
    22 Post(s)
    Quote Originally Posted by GQJETT View Post
    The RTC damper is only masking the problems, not fixing it. The wobbles will come back when the problem area wears more
    96 GQ coil/Cab
    08 G6eT
  11. #4210
    Jul 2014
    11 Post(s)
    I think the problem was with my draglink to be honest. It was the original one, I could move it all around by hand and the bushes had a visible 3-5mm of play when turning the wheels.
    '96 GQ TD42t
