Page 403 of 1465 FirstFirst ... 401402403404405 ... LastLast
Results 4,021 to 4,030 of 14641
  1. #4021
    @ JayCee, If your clutch fan is U/S you can rebuild it with some fluid from Toyota.
    Gently hose out the base [bottom] of your radiator dont use much pressure
    keep hosing till water runs clean. While you're at it you might as well hose the whole radiator
  2. The Following User Says Thank You to threedogs For This Useful Post:
    jay see (21st October 2014)
  3. #4022
    Drove it to the station and back again today and popped the bonnet as soon as I stopped this time touched the top of the radiator, both sides of the cap, hot touched the cap warm....
    Will get another cap and try that first. Going to change the fan and wash out the radiator. If that doesn't fix it, (I'm confident it will) I change the thermostat.
    Thanks TD, but if it was the clutch fan I'll probably just buy a new one. I know of some that have rebuilt theirs, some have worked and some haven't.
  4. #4023
    Nov 2010
    Getting a life...
    38 Post(s)
    A casual workforce that have the audacity to be 'unavailable' for work in Dec/Jan, then come Feb complain they get no work and cant feed their families...
    AND a company that dont have the balls to tell said workforce to be available or work some where else. There are plenty more people willing to work for a living no matter the time of year.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. The Following 6 Users Say Thank You to katwoman For This Useful Post:
    93patrol (21st October 2014), Clunk (21st October 2014), growler2058 (22nd October 2014), jack (22nd October 2014), Maxhead (22nd October 2014), Winnie (22nd October 2014)
  6. #4024
    177 Post(s)
    Must have run over some sort of grease or some s#it, and the tyre sent it flying all over the side of the car. Can't wash/hose it off, degreaser don't work, if I try and wipe it wet or dry, it just smears even more... And to make things worse my son walked out and touched it and now it's all over him...
    Up all, night little one copped fever and really high temps. No other symptoms... I really hope it's got nothing to do with this stuff he got on his hands.
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Hope it's not related. Probably not. Do wonder what it really was though?
    Thanks, Cameron
    No Patrol now - Just good memories!
  8. #4026
    Oct 2011
    Essendon
    Give some Orange oil or eucalyptus oil a go Hodgy. They dissolve almost anything.
    Sent from my iPhone using Forum Runner
  9. #4027
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I'm failing to see your point Kat
    Isn't that the whole point of "CASUAL" employment, so the person can choose when they want 2 work.
    If a company wanted people 2 work when they wanted them 2 work than they should employ permanent employees not casuals.
  10. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    menace 2 (22nd October 2014)
  11. #4028
    Or get more on the books.
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    I'm failing to see your point Kat Isn't that the whole point of "CASUAL" employment, so the person can choose when they want 2 work. If a company wanted people 2 work when they wanted them 2 work than they should employ permanent employees not casuals.
    Not entirely correct. Casual employment is that the company doesn't have enough work year round for a full time permanent position. So if your on a casual workforce, you can't complain that there's no work when you knocked back a job a couple of months prior.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  13. The Following 2 Users Say Thank You to Punderhead For This Useful Post:
    katwoman (23rd October 2014), NissanGQ4.2 (23rd October 2014)
  14. #4030
    Nov 2010
    Getting a life...
    38 Post(s)
    I can see your point, Toddie. 'Casual', I guess is open to interpretation. Our 'casual' work force also comes under the banner of 'on call'. You are under contract to work when the company has the work for you, not when ever you feel like working. They are also employed to cover for the permanents, when they have training or annual leave. And those that work when ever they want, have no right to complain when they constantly knock back work, and the phone stops ringing.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  15. The Following 6 Users Say Thank You to katwoman For This Useful Post:
    growler2058 (23rd October 2014), jack (23rd October 2014), macca (23rd October 2014), NissanGQ4.2 (23rd October 2014), relyimah (23rd October 2014), TPC (23rd October 2014)
