PM sent on locations for you
			Thanks a lot will check it out!
threedogs (21st October 2014)
				Remember you can only fit one to the drivers side using the existing captive nut on the side of the chassis
To fit two you'll need to drop the bullbar and fabricate a plate
to slide up inside the chassis[LHS] with nuts welded on.
RubberDuckieGQ (22nd October 2014)
			Thanks!
I'll check on my work laptop when i get there - couldn't see a link using the app
				You have a GQ don"t you
			yep 91 GQ
haha extra text because it said my msg too short to send! :O
				Thought so, Marks instructions will work to a point but he has a GU.
Easier to trace the holes onto a piece of steel that will slide up the lhs
Drill and weld some nuts on.
Your Avatar show no winch some it might be pretty easy
			My recovery points turned up today. Thanks very much John, awesome service and quality product. Ordered 11pm Tuesday night, waiting on my door step lunch time Thursday in Sydney, can't ask for much more.
Cheers Rod
My Build 2005 TD42TI
threedogs (25th October 2014)
			threedogs (27th October 2014)
