Page 401 of 1465 FirstFirst ... 399400401402403 ... LastLast
Results 4,001 to 4,010 of 14650
  1. #4001
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Either did a head gasket or cracked the head on my patrol. NOT HAPPY!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  2. #4002
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Punderhead View Post
    Ahhh bummer mate
  3. #4003
    Quote Originally Posted by Timbo15 View Post
    Got a letter from nissan saying my patrol has been recalled. something about a passenger airbag. oh how delightful only took them 11 years to realise.
    What was the recall for? Have you got a VIN number range for the recall mate as I may not get a letter but have a younger GU than yours.
  4. #4004
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    This one I would guess Daz
    http://www.recalls.gov.au/content/in...itemId/1060911
  5. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    MudRunnerTD (20th October 2014)
  6. #4005
    Apr 2013
    newcastle, nsw
    nissanGQ4.2 is spot on mudrunner.
  7. The Following User Says Thank You to Timbo15 For This Useful Post:
  8. #4006
    Oct 2014
    Bummer
    mate my missus did the head in her nissan so I feel for ya! Did you get any warning?
  9. #4007
    Seeing the temp gauge over half way.
    Have only been driving it to the station and back about 12 km return per day the last 2 months. Had to go a bit further today and while stopped at the lights the temp kept raising up to about 3/4. Once started driving quickly went back to its normal spot just under half. There was a cool breeze today.
    Once home had a good look around and noticed the fan has cracks around it. I have ordered a new one, but not 100% sure that this will fix the problem, could be that the clutch is not completely engaging? If that doesn't fix it I will check rad cap, then thermostat.
    After that I think it will need a bit more digging around. Hopefully not......
  10. #4008
    Expert relyimah's Avatar
    Carrum Downs, VIC
    I'd just do the viscous coupling at the same time mate. Unless the fan is spinning on the coupling then the cracks won't make a huge difference. They weren't too expensive from patrolapart when I got mine...
    1999 GU DX 4.2L | UFI 18g Turbo | Cross Country Intercooler | 2" Lift | 33" BF Goodrich KM2s
    WARNING: Towballs used for recoveries, can, and do kill people and damage property...No Excuses!
  11. The Following User Says Thank You to relyimah For This Useful Post:
    jay see (20th October 2014)
  12. #4009
    Quote Originally Posted by relyimah View Post
    Coupling feels OK, firm. I'll rather not change things if I don't need to.
    Did my boiling water test with the thermostat and once it was fully opened, I dropped it into cold water and after more than 2 minutes it was still about 2mm open.
    Looks like a new thermostat should fix it.
  13. The Following User Says Thank You to jay see For This Useful Post:
    relyimah (20th October 2014)
  14. #4010
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    coupling feels ok, firm. I'll rather not change things if i don't need to.
    Did my boiling water test with the thermostat and once it was fully opened, i dropped it into cold water and after more than 2 minutes it was still about 2mm open.
    after you do that mate see if you can do a 100k run to somewhere
    and home to clean out the gunk building up in the motor that will help also
  15. The Following User Says Thank You to Sir Roofy For This Useful Post:
