There is an inlet(top) and outlet(bottom) and a drain, but which way is the flow meant to go?
I'm assuming the inlet is coming from the crank case is this correct?
top inlet from the top of rocker coverat back of motor
bottom to side of motor just follow the hose you take off
oil outlet just a tap on the outlet hose and this is where i put mine
OH LEATHER IS NICE
Scottch (19th October 2014)
thanks, I thought that was right , just wanted to be 100%.
