Results 11 to 20 of 21
Thread: Rear Drawers final decisions
    I have a 50mm slide out table.
    Had plans to add 4 fold out legs to but having the 2 kids aswell it's not quite big enough.
    So we carry the blow moulded table on the racks..
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Dave , here a link to mine draw unit build and I just used some carpet strips on base of draw unit , works fine regards Alex
    http://www.nissanpatrol.com.au/forum...-for-under-450
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  3. The Following User Says Thank You to altech For This Useful Post:
    Smoothrun (20th October 2014)
  4. #13
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    Quote Originally Posted by Smoothrun View Post
    Thanks Rossco, I only wanted to use marine because I know how durable it is (had 5 boats), only prob is yep! flexibility, the auto carpet is on my list and has a bit more flex, IMO I recon it looks better too, it matches the car interior in appearance and color also (black), I am gunna use the Kwik Grip Gel for sticking it on as its a good product and price, considering the spray on but never used it.
    I just checked out the UES Slides and it seems IRS in WA and QLD sell an identical set, I typed in the model number I was given off the UES website and got the IRS product which gave an excellent overview including a you tube video to look at the slides in packaged,opened,extended,locked etc. well worth a look if anyones considering looking into 125KG fully extended 1800mm in total slides, UES had them for $66 non locking and $75 locking 900mm closed 1800mm extended. I'll head down there over the next week or so and have a physical look at them.
    The Full Boar Drawers are well worth a look at, Ive been on the website this week and may even give them a call, the prices he has on ebay are for a lower end setup (not quality just application) and Im looking for something which requires a modification or 2, If they come to the party Id be happy to purchase a locally sourced product, (with respect to other interstate Genuine Australian Manufacturers).
    Cheers and Thanks
    Locking are great because they hold the drawers open as well as shut, BUT you only really need one locking slide per drawer, so if you are making a pair of drawers buy one locking pair of slides and one pair of normal.
    Reason being if you have both sides locking it can be tricky to operate both locking latches and pull the drawer open at the same time.
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
  5. The Following 3 Users Say Thank You to Crate For This Useful Post:
    Rossco (17th October 2014), Smoothrun (23rd October 2014), threedogs (17th October 2014)
  6. #14
    Cheers and Thanks
    Hi Dave,
    Agreed the auto carpet does look good, matches the interior pretty well. I ended up recovering the inside of the doors and the side panels with the carpet too which looks really good. I also did a fold down table on the barn door which is one of the best things I've done to the 4by, and probably cost less than 20 bucks.
    Sounds like you got some pretty good prices on the sliders, I defiantly paid more than that for mine. Same as what Crate said about the lock out, they should be one of each if sold as a pair, but worth checking.
    Good luck, with mine I kind of just nutted it out along the way, and they came up pretty well. It was fun and is rewarding making them yourself, and can save some $$$. I can chuck up some photos if you like.
  7. The Following User Says Thank You to Rossco For This Useful Post:
    Smoothrun (22nd October 2014)
  8. #15
    Expert Smoothrun's Avatar
    Dec 2012
    Vic Melb
    Quote Originally Posted by altech View Post
    Thanks Alex, nice job, like the way you reused tie downs, given me an idea. Appreciated
  9. #16
    Dec 2012
    Vic Melb
    Thatd be grouse if ya wouldnt mind Rossco, any chance you have some of your barntable and upholstery, sounds interesting
  10. #17
    Dec 2012
    Vic Melb
    Appologies for late replies, and thanks for your input. I work long nights so me times limited for review,
    Feb 2014
    Iceland
    I did mine in marine carpet. The base plate and the top plate extend past the vertical sides by the thickness of the drawer fronts plus the thickness of the carpet.
    Wrapping the carpet on the drawer fronts is easy, just glue a piece on the front, then cut a slit from each corner, 45 degrees out and then tap the edges down with a mallet. The contact glue holds it well.
    I did mine this way to use the top and base to stop any possible rattle and the drawer sides had approx. 4mm gap between them.
    This means that when you slam the drawers shut, the front plates are completely jammed against each other and between the top and base
    The sliders came off Ebay and are rated 100Kg
    2009 ZD30-CRD Patrol ST Wagon. Bullbar, IPF Spotties, Snorkel, BFG285/70R70, 2" OME Lift, Rear Drawers, UHF, Scangauge, VDO Boost and EGT Gauges in an A-Pillar Pod, More bits
  12. The Following 3 Users Say Thank You to apalsson For This Useful Post:
    Rossco (20th October 2014), Smoothrun (22nd October 2014), Stropp (20th October 2014)
  13. #19
    No worries, I'll chuck some up in the next couple of days. . . a bit bloody busy ATM!!
  14. #20
    Hi Dave,
    Finally put up some photos, here's a link.
    http://www.nissanpatrol.com.au/forum...ar-Drawr-Build
  15. The Following User Says Thank You to Rossco For This Useful Post:
    Smoothrun (29th October 2014)
