Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: Squealing belt and/or pulley
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Could be the aircon compressor? As far as I know they won't engage at start up but once the car has been running for a moment it engages and switch on.
    How that relates to the noise, not sure, but the only thing I can think that could 'click' a few moments after the car is started
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  2. The Following User Says Thank You to lhurley For This Useful Post:
    Hodge (14th October 2014)
  3. #12
    177 Post(s)
    Quote Originally Posted by lhurley View Post
    That's the first thing I made sure, that the air-con is off, once i figured out that at some stage for some reason, squeal stops instantly, and something engages or disengages under the hood.
    So, just making sure... The alternators, on the common rails are so called smart alternators? As in they are clutch engaged? Anybody know?
    476 Post(s)
    They do have a clutch on them Eric. I know that much.
  6. #14
    Expert SG1's Avatar
    Sep 2014
    Gippsland, Vic
    Mine squeals a bit every morning, annoys the hell out of me, so switch it to "heat" to warm it up and noise goes away, think its the belt and prob should get a new genuine one anyway, and keep old one as a spare.
  7. The Following User Says Thank You to SG1 For This Useful Post:
    Hodge (15th October 2014)
  8. #15
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Make sure you buy an original belt. I don't know why - but the others all squeal after a short time - even the expensive ones.
  9. The Following User Says Thank You to BillsGU For This Useful Post:
  10. #16
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Sounds like the belt tensioner bearing to me dirty water has got in
    bit like bull dust got into mine you dont need to replace the lot just the bearing
    maybe $25 tops and 30min of your time
  11. #17
    Anyone know the size of the torque bolt on the tensioner pulley ?
  12. #18
    Thomastown, Melbourne
    6 Post(s)
    13mm??.... I did a GQ one today and it was 13mm aqnd the nut that held the pulley on was 17mm.
  13. #19
    476 Post(s)
    Are you talking about to release the tension on the arm so you can take the belt off? If so its 19mm. There's a cast hex on the arm.... The bolt that goes into the motor is 17mm (I think) then the two bolts for the shocker is 10 or 12mm... My brain is fried. I cant remember shite today...
  14. #20
    I brought an after market one and the chrome pulley is held on with a torq bit screw,
    I want to remove the pulley and replace the bearing with a known brand bearing
