Results 11 to 20 of 34
Thread: DIY winch cradle for GU alloy bar.
    Jan 2014
    Bathurst NSW
    Had a 1999 GU ST Patrol 4.5L Auto on Dual Fuel ...now have a 2003 GU ST ZD30TD Auto.
  2. #12
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    I stayed with 2 gauge and it seems to run fine. I get my cable from jaycar and I think I paid around $5 per meter with trade discount.
  3. The Following User Says Thank You to mjr350 For This Useful Post:
    tallman (10th October 2014)
  4. #13
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Quote Originally Posted by megatexture View Post
    Yea its (0 awg) 8.25 mm, what wire was 2 and swapped to 0? The main power supply?. Surely the didn't supply (2)6.5mm wire for that??
    The cabling supplied with my winch was 2 gauge (35mm2) and I swapped it all for 0 gauge and 50-8 lugs.
    I posted pics in my DIY thread - to which the OP included a link in post #1
    John
  5. The Following User Says Thank You to jff45 For This Useful Post:
  6. #14
    Morayfield, QLD
    Quote Originally Posted by tallman View Post
    When I researched before my installation I saw several mentioned using welding cable similar to that. You'll need some good 50mm2 lugs as well and get them crimped correctly.
    I bought my own hydraulic crimper - see pic in my thread.
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
  8. #15
    Sep 2014
    Port Macquarie
    My advice if you go with the welding cable is to cover it with conduit or colored heat shrink because we're taught in fire and rescue that orange leads are used on hybrid vehicles and can lead to a bit of confusion if your ever in an accident. I myself and many others would put 2 and 2 together but some old folk might get the wrong idea.
  9. The Following User Says Thank You to mjr350 For This Useful Post:
    tallman (11th October 2014)
  10. #16
    Jan 2014
    Brisbane
    That's mint man! I wish I had thought of something like this instead of spending a mint on an ARB bar..
  11. #17
    Jan 2014
    Bathurst NSW
    Spoke to local auto sparky and he said for the lengths of cable I'm running from winch to solenoid and to battery that 2 gauge would be more than adequate to do the job. He went on to say if I was to run longer lengths more than 3 meters then he would recommend a thicker gauge due to voltage drop.
  12. #18
    Sep 2014
    Port Macquarie
    The power cable that came with the winch was around a foot longer than the current extended cables I have so that tells me that the 2ga is plenty over that length. I've used it twice now with no issues what so ever.
  13. #19
    Jan 2014
    Bathurst NSW
    Ive taken the solenoid out of the control box and have mounted it the near the battery, just waiting on cable to arrive now. That black thin earth wire that comes off the solenoid, it was screwed to the inside of the control box, do I need to still use it?
  14. #20
    Sep 2014
    Port Macquarie
    Just hook the black wire from the solenoid straight to earth. That long thin wire was a jumper cable incase you mounted the control box on an area that's not earthed.
  15. The Following User Says Thank You to mjr350 For This Useful Post:
    tallman (14th October 2014)
