Results 1 to 10 of 10
Thread: Head stud kit for TB42
    Oct 2013
    Hi,
    Does anyone know where I can source a head stud kit for a TB42? I am told ARP is the way to go, but cannot find the TB42 as an engine type on their website...
    Thanks!
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    1999 GU 4500 dual fuel
    Il dado è tratto
  3. The Following User Says Thank You to NP99 For This Useful Post:
    swerver (10th March 2015)
    Apr 2013
    depends on where you are ?...All Head Services have them , plus everything else in relation to heads
    the one thing wrong with middle age ...is knowing you will grow out of it !
    Expert billyj's Avatar
    gordon
    cant say ive ever been able to find a kit, but might be possible to get the right size/length stud if you talk to one of their distributors, i know the thread is m10x1.5 and from memory the bolts are about 130mm long so you would need 140-150mm studs surely they would have something that would work
    Thomastown, Melbourne
    6 Post(s)
    Roodogs sells them... there are plenty of others that also sell them.
    Any particular reason you are wanting to use studs?
    Apr 2013
    its just terminology mate....they are bolts
    gordon
    i though he was meaning head studs instead of regular bolts, common to use studs and nuts insted of bolts in high performance applications
  10. #9
    This is what I was getting at. It have to be a decent build if it required head studs though. Nothing internally would be standard possibly the crank but yeah.
  11. #10
    gordon
    thinking more about it now, i have doubt you would be able to fit a head with the engine in place using studs on a tb42. to the op whats your aims for the motor? im running 9-10psi(should be 4 but have major boost creep) on a genuine gasket with no problems
