Can any body out there help me I have a 1992 2.8td 3dr patrol with only 55000mls on it I have owned it from new with no problems ,a month ago it was getting hard to select gears all the symptoms pointed to clutch master cylinder so I replaced it ,and it seemed to cure the problem for a while ,then the problem reappeared and it was impossible to select gears with the engine running ,then I lost drive completely so the gearbox came out and I found that the clutch had disintegrated which was surprising because there was no unusual noises to indicate that something was breaking up . The clutch has now been replaced but I am experiencing problems with the gears going in it seems that the clutch isnt releasing fully and holding the gears I have bled the clutch several times the pedal stays down and I have to lift it up when I am bleeding it ,can any body throw any light on what the problem may be.
Barry Lee
